#8911
Post
by RESET_9999 » Thu Sep 21, 2023 5:37 pm
quietvoid wrote: ↑Thu Sep 21, 2023 5:12 pm
I can't reproduce the issue even with DoviBaker, it looks normal but different from my method.
Haven't tested if my method is still accurate though.
Did you check the whole clip ?? its just some random frame that flashes. The first flash happens at frame 68.
if yes then I don't see how its possible and why its happening ONLY with the transformers movies. As I said I checked hundred of movies with the same avs script.
quietvoid
#8912
Post
by quietvoid » Thu Sep 21, 2023 6:18 pm
RESET_9999 wrote: ↑Thu Sep 21, 2023 5:37 pm
Yes I see them with DoviBaker only, my method looks fine.
It's probably a bug in DoviBaker.
skull88
#8913
Post
by skull88 » Thu Sep 21, 2023 6:26 pm
Just curious, how did you catch this originally, if it's only certain frames? Is it not possible other movies from that period and studio might have similar issue if passed through, but the exact frames just never showed up for a movie you haven't watched yet or are they obvious on DV plot or some other way without scrubbing/watching entire file?
skull88 on Thu Sep 21, 2023 6:30 pm, edited 2 times in total.
#8914
Post
by RESET_9999 » Thu Sep 21, 2023 6:28 pm
skull88 wrote: ↑Thu Sep 21, 2023 6:26 pm
Just curious, how did you catch this, if it's only certain frames? Is it not possible other movies have it but the exact frames just never showed up or are they obvious on DV plot or some other way without scrubbing/watching entire file?
with workflow 7-1 , I export 50 screenshots and got at least 10 faulty frames with both Transformers movies.
none of the other FEL movies I checked had this issue.
skull88
#8915
Post
by skull88 » Thu Sep 21, 2023 6:30 pm
RESET_9999 wrote: ↑Thu Sep 21, 2023 6:28 pm
Ah, okay. I wonder if these specific frames have any unique/unusual data if you look at the .json from the FEL RPU? Otherwise, it may just be something in the HEVC encoding and DoViBaker combination bug I guess. Strange find though.
Iam2smart
#8916
Post
by Iam2smart » Thu Sep 21, 2023 6:38 pm
I'm having an issue where I'm trying to inject Web DV into Blu-ray HDR10 I'm using National Lampoons Christmas Vacation and I followed the video tut but I keep getting this error to reset displays to all level9 to the mastering display and it also states the L2 Metadata Validation test fails and L9 Metadata Validation test fails any ideas? Thanks
#8917
Post
by RESET_9999 » Thu Sep 21, 2023 7:20 pm
Iam2smart wrote: ↑Thu Sep 21, 2023 6:38 pm
AFAIK, there's only an iTunes webdl available and it's cmv2.9 (no L9).
So I guess you have a MA webdl ? can you post the result of the metafier validation please? (workflow 2-8)
Iam2smart
#8918
Post
by Iam2smart » Thu Sep 21, 2023 7:43 pm
RESET_9999 wrote: ↑Thu Sep 21, 2023 7:20 pm
Here is the attached file I tried to find the iTunes Version but this is the only one I found from the places I use
Edit. I realized it didnt even attach the file here is a google drive link
https://drive.google.com/file/d/1P_JtiJ ... drive_link
Iam2smart
#8919
Post
by Iam2smart » Thu Sep 21, 2023 7:47 pm
I also have the issue with Elf just no L9 error its a bunch of L2 errors but I have the same file that is listed in the screenshots on the Google Sheets So maybe its my setup?
#8920
Post
by RESET_9999 » Thu Sep 21, 2023 8:30 pm
You also have to allow external access to your file.
Iam2smart wrote: ↑Thu Sep 21, 2023 7:47 pm
I'm guessing you're getting warnings and not errors? warnings is fine.
WARNING: 77 Shots contain identical Level2 values
Iam2smart
#8921
Post
by Iam2smart » Thu Sep 21, 2023 8:38 pm
RESET_9999 wrote: ↑Thu Sep 21, 2023 8:30 pm
Oops that’s my bad I enabled access, it lists it as an error. This is what it lists
ERROR: Undefined Level2 Target Display with ID: 27 at shot
then it’s a bunch of characters and there’s a lot of the errors and it’s just that same as that. Does L2 Metadata have to pass a Validation Test?
Iam2smart
#8922
Post
by Iam2smart » Thu Sep 21, 2023 9:16 pm
Ive learned that I do have the MA (or at least im assuming the plot of mine looks different then the one on the sheet) of National Lampoons Christmas Vacation I wish i could find the iTunes version ive searched and searched but cant find it with what i have access to
danbez
#8924
Post
by danbez » Thu Sep 21, 2023 10:19 pm
quietvoid wrote: ↑Thu Sep 21, 2023 6:18 pm
@quietvoid, can you explain your method ? Or send a link where I can learn about it? Thanks!
#8925
Post
by Coopervid » Fri Sep 22, 2023 12:01 am
I check this thread from time to time but I have asked myself why you guys go through all that trouble.
An Oppo clone plays everything you throw at it besides profile 8 and 5. And there are now ways to convert profile 8 back to profile 7 and the outcome DV is clearly better quality than profile 8 - at least the same. Is it just to save some bucks not to buy an Oppo clone? And have hassles here and there and fumble with things instead to load a movie and enjoy it in full quality? Guys - that's nuts. And much too consuming time. Like in the old days: Life is too short to do video on a PC.
