ESPN 30 for 30 DVD 6 Title 01
Tran101
Post by Tran101 » Tue Jun 21, 2011 11:27 pm
Problem doing a backup of Title01 of DVD 6 of the box set 1
MakeMKV v1.6.10 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/tran801/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KC08" opened in DASPI v1.3 mode.
Optical drive "BD-ROM HL-DT-ST BDDVDRW CT21N 1.00" opened in DASPI v1.3 mode.
Title #0 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 was added (4 cell(s), 0:51:37)
Title #4 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (4 cell(s), 0:51:33)
Title #6 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 was added (1 cell(s), 0:03:36)
Title #9 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 was added (1 cell(s), 0:02:46)
Title #11 was added (1 cell(s), 0:02:24)
Title #12 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 was added (1 cell(s), 0:02:05)
Title #14 was added (1 cell(s), 0:03:04)
Title #15 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/FILESHARE/Library/Staging
DEBUG: Code 6 at WCELrB5uaWyht:121263820
DEBUG: Code 0 at WCELrB5uaWyht:29394896
DEBUG: Code 0 at S56I+,8bi4aN!%|eIo\:121263912
DEBUG: Code 0 at _y.Wha8OK(K)>ze|cZy3:29394298
DEBUG: Code 0 at T[nr*XQA:~|G/QT$oOp:213130191
DEBUG: Code 0 at _y.Wha8OK(K)>ze|cZy3:29394183
DEBUG: Code 6 at _y.Wha8OK(K)>ze|cZy3:29393309
DEBUG: Code 0 at Y'/Q/G2y`KkX'gJHx[0[I:29397472
DEBUG: Code 0 at d7B3>Y]}#0^XS4`Ic2|:121263843
DEBUG: Code 0 at d7B3>Y]}#0^XS4`Ic2|:121265752
DEBUG: Code 0 at d7B3>Y]}#0^XS4`Ic2|:213130536
DEBUG: Code 0 at d7B3>Y]}#0^XS4`Ic2|:29393723
DEBUG: Code 0 at Y'/Q/G2y`KkX'gJHx[0[I:29397587
DEBUG: Code 0 at K|F_.cWTO'%ld'3jn:L:29394160
DEBUG: Code 0 at K|F_.cWTO'%ld'3jn:L:29395471
Failed to save title 1 to file /Volumes/FILESHARE/Library/Staging/title01.mkv
0 titles saved, 1 failed
Re: ESPN 30 for 30 DVD 6 Title 01
Post by mike admin » Thu Jun 23, 2011 12:50 pm
Sometimes, even if you have a good drive, DVD discs with mismatched region can't be copied. This happens very rarely - you have a bad luck. Your only choice is to copy this disc on a drive with matching DVD region.
