asus bw-16d1h-u pro downgrade??
carglez
Post by carglez » Thu Sep 21, 2023 12:22 pm
I have bought an asus bw-16d1h-u pro... The brand tells me to apply a downgrade from the version it has (A205) to the A204 version... Why?
Tx
Re: asus bw-16d1h-u pro downgrade??
Post by Billycar11 » Thu Sep 21, 2023 12:38 pm
The brand Asus?
I don't think you are barking up the right tree if your asking Asus about this
carglez
Post by carglez » Thu Sep 21, 2023 2:25 pm
Let me explain: The manual says to apply the firmware update that indicates a link. The link takes you to download the A204 firmware, but MakeMKV or DVDInfo say that the version of the drive is A205, that is, a later firmware. That's why my question: Why should I downgrade the unit's firmware? ...Is it necessary for it to be "friendly"? ...Will you need it to make it 4K compatible?
TX
Ezatoka
Post by Ezatoka » Thu Sep 21, 2023 2:40 pm
carglez wrote: Thu Sep 21, 2023 2:25 pmIs it necessary for it to be "friendly"? ...Will you need it to make it 4K compatible?
More often than not manufacturers give out new firmwares to make drives (more) unfriendly at all.
What is the drive information MakeMKV lists on the right side when you start the program?
Post by Coopervid » Thu Sep 21, 2023 3:14 pm
carglez wrote: Thu Sep 21, 2023 2:25 pm Let me explain: The manual says to apply the firmware update that indicates a link. The link takes you to download the A204 firmware, but MakeMKV or DVDInfo say that the version of the drive is A205, that is, a later firmware. That's why my question: Why should I downgrade the unit's firmware? ...Is it necessary for it to be "friendly"? ...Will you need it to make it 4K compatible?
TX
Forget that link and make your drive UHD friendly with 204 MK. See Billy's guide:
viewtopic.php?f=16&t=19634
carglez
Post by carglez » Thu Sep 21, 2023 4:54 pm
ASUS BW-16D1H-U PRO
Info MakeMKV:
Información de unidad de disco
Nombre del SO del dispositivo: E:
Fabricante: ASUS
Producto: BW-16D1H-U
Revisión: A205
Número de serie: ***********
Fecha del firmware: 2120-12-01 18:18
Marcas de cifrado bus: 1F
Highest AACS version: 35
Post by Coopervid » Fri Sep 22, 2023 3:36 pm
Do what I posted above your last post.
x10bulls
Post by x10bulls » Wed Nov 22, 2023 5:29 pm
@carglez did you ever get it to downgrade to A204?
I am trying to get a firmware version that can rip PS3 discs.. I know the BW-16D1HT can do that, but thought the BW-16D1H-U PRO is the same drive, doesn't seem like it.
x10bulls
Post by x10bulls » Thu Nov 23, 2023 11:25 am
I have this:
Drive F:
Description CD-ROM Drive
Firmware E116
Media Loaded No
Media Type DVD Writer
Name ASUS BW-16D1H-U USB Device
Manufacturer (Standard CD-ROM drives)
Status OK
Transfer Rate -1.00 kbytes/sec
SCSI Target ID 0
PNP Device ID USBSTOR\CDROM&VEN_ASUS&PROD_BW-16D1H-U&REV_E116\123456789012&0
Driver C:\WINDOWS\SYSTEM32\DRIVERS\CDROM.SYS (10.0.22621.1, 200,00 KB (204 800 bytes), 2022/05/07 07:19)
Post by Billycar11 » Thu Nov 23, 2023 11:37 am
x10bulls wrote: Thu Nov 23, 2023 11:25 am I have this:
Drive F:
Firmware E116
Media Loaded No
Status OK
SCSI Target ID 0
Nah man the makemkv drive info we are on makemkv
But it seems like it's a pioneer it's a better drive for UHD but yeah don't think any of the pioneers see ps3 discs only LG drives do or Asus rebranded LG drive would be safer to get an LG wh16 so you don't end up like this again or the wh14 if it's cheaper
