I have bought an asus bw-16d1h-u pro... The brand tells me to apply a downgrade from the version it has (A205) to the A204 version... Why?
Tx
asus bw-16d1h-u pro downgrade??
Re: asus bw-16d1h-u pro downgrade??
The brand Asus?
I don't think you are barking up the right tree if your asking Asus about this
carglez
Let me explain: The manual says to apply the firmware update that indicates a link. The link takes you to download the A204 firmware, but MakeMKV or DVDInfo say that the version of the drive is A205, that is, a later firmware. That's why my question: Why should I downgrade the unit's firmware? ...Is it necessary for it to be "friendly"? ...Will you need it to make it 4K compatible?
TX
TX
Ezatoka
More often than not manufacturers give out new firmwares to make drives (more) unfriendly at all.carglez wrote: Thu Sep 21, 2023 2:25 pmIs it necessary for it to be "friendly"? ...Will you need it to make it 4K compatible?
What is the drive information MakeMKV lists on the right side when you start the program?
Forget that link and make your drive UHD friendly with 204 MK. See Billy's guide:carglez wrote: Thu Sep 21, 2023 2:25 pm Let me explain: The manual says to apply the firmware update that indicates a link. The link takes you to download the A204 firmware, but MakeMKV or DVDInfo say that the version of the drive is A205, that is, a later firmware. That's why my question: Why should I downgrade the unit's firmware? ...Is it necessary for it to be "friendly"? ...Will you need it to make it 4K compatible?
TX
viewtopic.php?f=16&t=19634
carglez
ASUS BW-16D1H-U PRO
Info MakeMKV:
Información de unidad de disco
Nombre del SO del dispositivo: E:
Fabricante: ASUS
Producto: BW-16D1H-U
Revisión: A205
Número de serie: ***********
Fecha del firmware: 2120-12-01 18:18
Marcas de cifrado bus: 1F
Highest AACS version: 35
Info MakeMKV:
Fabricante: ASUS
Revisión: A205
Do what I posted above your last post.
x10bulls
@carglez did you ever get it to downgrade to A204?
I am trying to get a firmware version that can rip PS3 discs.. I know the BW-16D1HT can do that, but thought the BW-16D1H-U PRO is the same drive, doesn't seem like it.
x10bulls
I have this:
Drive F:
Description CD-ROM Drive
Firmware E116
Media Loaded No
Media Type DVD Writer
Name ASUS BW-16D1H-U USB Device
Manufacturer (Standard CD-ROM drives)
Status OK
Transfer Rate -1.00 kbytes/sec
SCSI Target ID 0
PNP Device ID USBSTOR\CDROM&VEN_ASUS&PROD_BW-16D1H-U&REV_E116\123456789012&0
Driver C:\WINDOWS\SYSTEM32\DRIVERS\CDROM.SYS (10.0.22621.1, 200,00 KB (204 800 bytes), 2022/05/07 07:19)
Drive F:
Firmware E116
Media Loaded No
Status OK
SCSI Target ID 0
Nah man the makemkv drive info we are on makemkvx10bulls wrote: Thu Nov 23, 2023 11:25 am I have this:
Drive F:
Firmware E116
Media Loaded No
Status OK
SCSI Target ID 0
But it seems like it's a pioneer it's a better drive for UHD but yeah don't think any of the pioneers see ps3 discs only LG drives do or Asus rebranded LG drive would be safer to get an LG wh16 so you don't end up like this again or the wh14 if it's cheaper
