Failed to execute external program 'java' (tried several locations)
wsdickerson
#1 Post by wsdickerson » Mon Sep 18, 2023 3:51 pm
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java.
Using Java runtime from /run/user/1000/doc/1dee089c/java
-rw-r--r-- 0 USER GROUP 8.8k Jun 9 2021 /run/user/1000/doc/1dee089c/java
Failed to execute external program 'java' from location '/run/user/1000/doc/1dee089c/java'
Failed to execute external program 'java' from location '/usr/bin/java'
openjdk version "11.0.11" 2021-04-20
Using Java runtime from /usr/bin
Failed to execute external program 'java' from location '/usr/bin'
Using Java runtime from /usr/java/jre/bin
Failed to execute external program 'java' from location '/usr/java/jre/bin'
Using Java runtime from /usr/java/jre/bin/java
Failed to execute external program 'java' from location '/usr/java/jre/bin/java'
/usr/java/jre/bin/java -version
java version "1.8.0_301"
Re: Failed to execute external program 'java' (tried several locations)
#2 Post by Woodstock » Mon Sep 18, 2023 5:40 pm
Java is not included in MakeMKV, so ... where do you have it installed? Is it tagged as executable?
wsdickerson
#3 Post by wsdickerson » Mon Sep 18, 2023 10:39 pm
Java 1.8 is in /usr/java/jre/bin.
I also tried the directory without "java".
Ezatoka
#4 Post by Ezatoka » Tue Sep 19, 2023 6:36 am
That first example doesn't has the eXecutable-Permission. How about the others? I'm not a Unix professional, but maybe it has something to do with that.
wsdickerson
#5 Post by wsdickerson » Tue Sep 19, 2023 1:31 pm
It is also size 0. I only listed that because makeMKV kept using that if I used the Java selection instead of typing in a path.
FYI, the disc failed to play last night in my PS4 and only played about half in my PS5. I wouldn't think that caused the problem because I think it looks for Java before it starts reading the disc.
#6 Post by Woodstock » Tue Sep 19, 2023 3:27 pm
Just a wild thought, but... do you have something listed in the "Custom Java executable location" line, or is it blank?
Mine's been blank "forever", and I never see that error, maybe because I don't have disks that trigger looking for Java. Java is not used for "every" disk.
wsdickerson
#7 Post by wsdickerson » Tue Sep 19, 2023 6:07 pm
Maybe it was just a bad disc. I tried another with "Custom Java executable location" =/usr/bin and got:
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
I tried again with custom java executable location blank and got the same result and two more movies.
I'll respond again if I see that error again.
