Failed to execute external program 'java' (tried several locations)
wsdickerson
Post by wsdickerson »
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java.
Using Java runtime from /run/user/1000/doc/1dee089c/java
-rw-r--r-- 0 USER GROUP 8.8k Jun 9 2021 /run/user/1000/doc/1dee089c/java
Failed to execute external program 'java' from location '/run/user/1000/doc/1dee089c/java'
Failed to execute external program 'java' from location '/usr/bin/java'
openjdk version "11.0.11" 2021-04-20
Using Java runtime from /usr/bin
Failed to execute external program 'java' from location '/usr/bin'
Using Java runtime from /usr/java/jre/bin
Failed to execute external program 'java' from location '/usr/java/jre/bin'
Using Java runtime from /usr/java/jre/bin/java
Failed to execute external program 'java' from location '/usr/java/jre/bin/java'
/usr/java/jre/bin/java -version
java version "1.8.0_301"
Re: Failed to execute external program 'java' (tried several locations)
Java is not included in MakeMKV, so ... where do you have it installed? Is it tagged as executable?
wsdickerson
Java 1.8 is in /usr/java/jre/bin.
I also tried the directory without "java".
Ezatoka
Post by Ezatoka »
wsdickerson wrote:
Mon Sep 18, 2023 3:51 pm
That first example doesn't has the eXecutable-Permission. How about the others? I'm not a Unix professional, but maybe it has something to do with that.
wsdickerson
It is also size 0. I only listed that because makeMKV kept using that if I used the Java selection instead of typing in a path.
FYI, the disc failed to play last night in my PS4 and only played about half in my PS5. I wouldn't think that caused the problem because I think it looks for Java before it starts reading the disc.
Just a wild thought, but... do you have something listed in the "Custom Java executable location" line, or is it blank?
Mine's been blank "forever", and I never see that error, maybe because I don't have disks that trigger looking for Java. Java is not used for "every" disk.
wsdickerson
Maybe it was just a bad disc. I tried another with "Custom Java executable location" =/usr/bin and got:
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
I tried again with custom java executable location blank and got the same result and two more movies.
I'll respond again if I see that error again.
