Back to the Future III fails with corrupt source error
Revenent
Post by Revenent »
So I've tried this against both the original disc, and the files that DVDFab outputs. Both give pretty much the exact same error (even the offsets are identical).
I've tried playing the disc and the image using multiple players and there doesn't seem to be any issues with the disc or image.
(This occurs on both x64 and x86 releases - tried both just to make sure.)
Here's the log from the DVDFab generated files:
MakeMKV v1.6.10 win(x86-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Opening files on harddrive at //Server/images/Movies/Back to the Future Part III/
AACS directory not present, assuming unencrypted disc
Title #00013.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.mpls was added as title #0
File 00800.mpls was added as title #1
Title #01055.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01056.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00010.m2ts was added as title #2
File 00011.m2ts was added as title #3
Title #00050.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00272.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00302.m2ts was added as title #4
File 00303.m2ts was added as title #5
Title #00304.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00305.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00306.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00307.m2ts was added as title #6
File 00308.m2ts was added as title #7
File 00309.m2ts was added as title #8
File 00310.m2ts was added as title #9
Title #00312.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00313.m2ts was added as title #10
File 00314.m2ts was added as title #11
File 00317.m2ts was added as title #12
Title #00326.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50057.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50058.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory N:/Streams
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218825216, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218831360, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218837504, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218843648, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218849792, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218855936, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218862080, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218868224, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218874368, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218880512, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 19218886656, attempting to work around
Failed to save title 1 to file N:/Streams/title01.mkv
0 titles saved, 1 failed
setarip_old
Re: Back to the Future III fails with corrupt source error
Post by setarip_old »
Hi!
Pre-processing and/or ripping with programs other than MakeMKV is not acceptable for performing beta testing and bug reporting of MakeMKV (The purpose of this forum).
Please use MakeMKV to DIRECTLY rip and backup your original, commercial disc and submit its debug log...
Post by mike admin »
Please try to do a full disc backup per instructions at http://www.makemkv.com/faq/item/4/catid/4 . If you get any hatcheck error then it's a bad disc. If not, then it's either a disc mastering error or bug in MakeMKV. Please do the backup first and post the result here.
