zimor76
Re: SDFtool Flasher
Hi Marty. I am having problem Flashing my LG drive. I do think its because I am running Win 7, and not Win 10? Is this a problem? I get an error when I try to flash the drive. Help?
Re: SDFtool Flasher
Yep probably.zimor76 wrote: Wed Sep 13, 2023 11:15 pm Hi Marty. I am having problem Flashing my LG drive. I do think its because I am running Win 7, and not Win 10? Is this a problem? I get an error when I try to flash the drive. Help?
Requirements:
Windows 10 (or 11) 64 bit version
MakeMKV v1.15.1 (or higher) installed
.NET Framework 4.7.2 **only for SDFtool Flasher v1.2.0**
tlhcpu
Re: SDFtool Flasher
Manufacturer: MATSHITA
Product: BD-MLT UJ260
Revision: 1.00
Serial number: HM09 048723
do you have any thing for this
Revision: 1.00
Re: SDFtool Flasher
No.tlhcpu wrote: Thu Sep 14, 2023 5:23 pm Manufacturer: MATSHITA
Revision: 1.00
Arthan
Re: SDFtool Flasher
Hi, I have BH16NS55 with 1.05 firmware and I want to install the BW-16D1HT_3.10_MK firmware. I'm not sure whether I should check the "encrypted firmware" option.
I dumped my firmware and I got "dump_user_HL-DT-ST_BD-RE__BH16NS55_1.05_212006181342_K9THC2E1735.tar", which seems different than "HL-DT-ST-BD-RE_BH16NS55-1.05-N000400-212004211049.bin" mentioned in the encrypted firmware list in the first post.
Re: SDFtool Flasher
The dump is not the complete firmware file. It's a tar (zip) file containing just the important parts of the firmware.Arthan wrote: Fri Sep 15, 2023 12:39 pm Hi, I have BH16NS55 with 1.05 firmware and I want to install the BW-16D1HT_3.10_MK firmware. I'm not sure whether I should check the "encrypted firmware" option.
The latest version of SDFtool Flasher should automatically detect and set the encrypted firmware flag for you. I also suggest you flash WH16NS60 1.02-MK firmware as it is much better than the ASUS firmware.
Arthan
Re: SDFtool Flasher
Thanks, I actually just downgraded with "DE_LG_BH16NS55_1.02.bin" so my drive can properly read lead out when dumping CDs as per the guide here.MartyMcNuts wrote: Sat Sep 16, 2023 10:15 pm I also suggest you flash WH16NS60 1.02-MK firmware as it is much better than the ASUS firmware.
Panda04
Re: SDFtool Flasher
Thanks Marty, I installed MakeMKV to the default path. MakeMKV Does not see the drive. But SDFToolFlaser did. I did a read then a write and I got the following error. 0x82052400 and the drive did not flash.MartyMcNuts wrote: Mon Sep 11, 2023 8:04 pmYou must have MakeMKV installed in the default location which should be: C:/Program Files (x86)/MakeMKV.Panda04 wrote: Mon Sep 11, 2023 2:52 pm I'm having the same issue. Windows 11 see the drive but SDFlasher Tool doesn't not show it in the drive popup.
The drive is an Ausus BW-16D1HT.
Any suggestions on getting this to work?
TIA
TIA Panda
stankubrick
Re: SDFtool Flasher
Apologies if this is a dumb question. But what is the difference between;
DE_LGBP60NB10_1.02-MK.bin and
DE_LG_BP60NB10-NB12_1.02-MK.bin
Re: SDFtool Flasher
Post your MakeMKV drive info text (right side)Panda04 wrote: Mon Sep 18, 2023 2:52 pmThanks Marty, I installed MakeMKV to the default path. MakeMKV Does not see the drive. But SDFToolFlaser did. I did a read then a write and I got the following error. 0x82052400 and the drive did not flash.MartyMcNuts wrote: Mon Sep 11, 2023 8:04 pmYou must have MakeMKV installed in the default location which should be: C:/Program Files (x86)/MakeMKV.Panda04 wrote: Mon Sep 11, 2023 2:52 pm I'm having the same issue. Windows 11 see the drive but SDFlasher Tool doesn't not show it in the drive popup.
TIA
TIA Panda
Panda04
Re: SDFtool Flasher
Drive info:
OS device name: /dev/rdisk5
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLZN16G2601
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 62
Disc Information
Label: PASSENGERS_2016
Timestamp: 2017-01-25 12:33:46
Protection: AACS v62
Data capacity: 37.40 Gb
Disc type: BD-ROM
Number of layers: 2
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Disc Information
Disc type: BD-ROM
Number of layers: 2
Re: SDFtool Flasher
So, using SDFTool Flasher (latest version), you should see a green tick for both "MT1959 Drive Platform" and "Encrypted Firmware". If you don't see a green tick for "Encrypted Firmware" but see a red X, click the red X to toggle it to a green tick. Also, before attempting to flash the drive, make sure the drive tray is empty and closed.Panda04 wrote: Mon Sep 18, 2023 11:54 pm Drive info:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Disc Information
Disc type: BD-ROM
Number of layers: 2
Now, I'm not sure what firmware you tried to flash but you only have 2 options to start with. You can flash either ASUS BW-16D1HT 3.10-MK or WH16NS60 1.02-MK. Use the ASUS firmware if you often write discs. If you rarely write discs use the WH16NS60 1.02-MK. It is the recommended firmware as it is fastest and removes the sleep bug. Both of these firmwares work well with MakeMKV and AnyDVD. They do not work with DVDFab. If you use that software, once you have flashed either of the above mentioned firmwares, you can then flash the drive to ASUS BW-16D1HT 3.02 or WH16NS60 1.00, as both of these work with all popular ripping software.
Panda04
Re: SDFtool Flasher
Thank you Marty,
I followed your directions and received the following error: Oxff056108
Andy
Andy
Re: SDFtool Flasher
If there was a disc in the drive, remove it. Drive must be empty.
Panda04
Re: SDFtool Flasher
Opps,
My daughter had left a disc in the drive.
Thank you,
Andy
Thank you,
Andy
