Using a Pioneer BDR-XS07S
Disk does not open with Mac OS, opens fine with Windows 11.
Close Encounters of the 3rd Kind 40th
Re: Close Encounters of the 3rd Kind 40th
likly a key error you need to get the hk on the mac why its blocked idk
coule be this and more...
firewall
dns
vnp
try using/disabling or changing all those and see if it works
firewall
dns
vnp
hulkss
Moved the drive from my Windows machine back to my Mac Studio.
The disk loads and opens fine now. I did nothing, so, probably just a sensitive disk that's not perfectly clean.
