BH16NS50
horrofiend666
BH16NS50
#1 Post by horrofiend666 » Fri Sep 15, 2023 8:09 pm
anything im doing wrong here?
OS device name: /dev/sr0
Product: BD-RE BH16NS50
Revision: 1.03
Serial number: KLKK7LG4227
Firmware date: 2120-04-21 09:58
Highest AACS version: 76
Firmware version: 1.03
Disc Information
Label: THE_LOST_BOYS
Timestamp: 2022-07-19 14:05:46
Protection: AACS2.0/C v76
Data capacity: 56.86 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.17.4 linux(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Failed to get full access to drive "HL-DT-ST BD-RE BH16NS50". Make sure that you either have write access to device "/dev/sr0", are member of "cdrom" group or have CAP_SYS_RAWIO enabled.
Backing up disc into folder "/home/dantexaiver/backup/THE_LOST_BOYS"
Saved AACS dump file as /home/dantexaiver/snap/makemkv/618/.MakeMKV/MKB20_v76_THE_LOST_BOYS_7A6B.tgz
Backup failed
Re: BH16NS50
#2 Post by Billycar11 » Sat Sep 16, 2023 12:20 am
horrofiend666 wrote: Fri Sep 15, 2023 8:09 pm anything im doing wrong here?
Revision: 1.03
Disc Information
Number of layers: 2
Backup failed
pass through error is this a container/docker?
sandman416
Re: BH16NS50
#3 Post by sandman416 » Thu Sep 21, 2023 4:20 pm
Did you install with the software center? My guess is it sandboxed it. In other words kept it from the CDROM group. I did the same thing because my older version had not updated and I wasn't in the mood to download all the files and do a manual install. I am not sure where to update the group, if there is someone who knows please provide that information.
