The Warriors -- UPC code 0 32429 31828 2
hart2hart
#1 Post by hart2hart » Fri Sep 15, 2023 2:25 pm
This disk lists as being AACS 4 and it will not backup. See attached screenshot. I'll email the log file.
Re: The Warriors -- UPC code 0 32429 31828 2
#2 Post by dcoke22 » Fri Sep 15, 2023 4:28 pm
hart2hart wrote: Fri Sep 15, 2023 2:25 pm This disk lists as being AACS 4 and it will not backup. See attached screenshot. I'll email the log file.
There's no attached screenshot. The board's storage for attachments has been full lately.
Just post your log here.
hart2hart
#3 Post by hart2hart » Fri Sep 15, 2023 5:05 pm
Log and screenshot attached.
It says board quota exceeded...I have already emailed MKB_v4_save.tgz Is that the correct file?
#4 Post by dcoke22 » Fri Sep 15, 2023 6:25 pm
hart2hart wrote: Fri Sep 15, 2023 5:05 pm Log and screenshot attached.
You're going to have to copy & paste the text of your log into a post on here.
Wrap it inside a 'code' block if you like.
Generally speaking, the only time one needs to email in a dump file is with a UHD with an unknown key. Regular blu-rays should just work.
hart2hart
#5 Post by hart2hart » Fri Sep 15, 2023 7:16 pm
Remind me where is the log file. The tgz file is outside normal print set.
#6 Post by dcoke22 » Fri Sep 15, 2023 7:30 pm
On my Mac the log file named MakeMKV_log.txt is just in my home account. On Windows it is probably in C:\Users\<username>\MakeMKV_log.txt. The log should contain the same thing as the bottom half of the MakeMKV window. Near the top of the data printed out there also includes the location of the log file.
By default, every time you start MakeMKV it overwrites the log file with a new one.
hart2hart
#7 Post by hart2hart » Sat Sep 16, 2023 4:17 pm
Still can't attach anything. What next?
#8 Post by Woodstock » Sun Sep 17, 2023 3:18 am
Not attached - emailed to svq@makemkv.com for processing. That gets it to the person who can deal with it fastest.
hart2hart
#9 Post by hart2hart » Sun Sep 17, 2023 3:59 am
Thanks. I emailed it before I even attempted the post.
