All Quiet on the Western Front (2022) - DV issue
Re: All Quiet on the Western Front (2022) - DV issue
kkienle wrote:
Thu Sep 14, 2023 10:27 pm
Hello! I am super noob on ripping UHDs, just getting started, and I dont follow the backup.
WOuld you mind explaining this MakeMKV backup function (tick "decrypt video") process? Or could you share anything on this?
After you put your disc in your optical drive and MakeMKV does an initial read, click the backup icon instead of the normal rip-a-movie workflow. The backup icon is along the top, it is a yellow folder with a green arrow pointing into it.
It will copy the contents of a disc to your storage. It'll be the standard folder structure in the case of a blu-ray or UHD and an .iso file in the case of a DVD.
Later, MakeMKV can read the contents of the backup to produce .mkv files if you so wish.
Stryker412
Post by Stryker412 »
Just out of curiosity, I just received this disc today. Is this still an issue? I have the HMV version (UK).
