Mrmorrison
#8851 Post by Mrmorrison » Thu Sep 14, 2023 4:17 pm
DV FEL (first file) - X800M2
DV 8 (movie ST SL P7 FEL converted with DoviScript) - Sony Bravia A8H
I must be sincere. To the naked eye, without having two televisions next to each other, I don't notice any difference. Contrary to what happened with FAST X, with this film there isn't such a clear difference. Perhaps from the photos the FEL has a very slight bluer tone but I really can't find any differences. What do you think about it?
I found the entire movie and converted it with your tool without modifying L5
#8852 Post by RESET_9999 » Thu Sep 14, 2023 4:29 pm
well as you have shown in your FAST X comp, regardless of FEL, there is a difference between your BD player and internal tv player(tv being brighter , cooler).
So those comparison looks as expected IMO because the P8 file has wrong metadata for the BL brightness, which makes it much darker than it should. This is the reason why the brightness ''almost'' looks like FEL playback on the x800m2.
If you try the test file that has properly generated P8 metadata (resolve), then like FASTX, it should look brighter using your TV internal player.
But it does look like your TV internal app(looks warm) DV has a different temperature settings than your HDMI input (looks cool)
Zomboy101
#8853 Post by Zomboy101 » Thu Sep 14, 2023 7:48 pm
hey again, - audio format question
firstly this tool is great I've been using it a lot , thanks again for the help with the tools.
I mostly use the scripts to convert p7 mkv files, to p8 ts for my LG C1.
lg support says that ts files with pcm audio are supported.
https://www.lg.com/us/support/help-libr ... 3095976198
but trying to convert with the script returns something like "unsupported audio format" and stops the conversion.
I tried taking the HEVC p8 file created and mux it myself successfully,
can this be fixed in the batch file?
Mrmorrison
#8854 Post by Mrmorrison » Thu Sep 14, 2023 8:44 pm
Picture settings are the same for HDMI and video apps. :(
So how do you advise me to act?
If the movie is fel but the fel does not extend the brightness, is it better for me to convert to p8 since the TV is brighter and more colourful?
Instead, when I have a FEL that extends the brightness (by the way, how do I understand it?) should I reproduce it with x800m2?
So
Sony Bravia for:
- P7 FEL convered to P8 if it does not extend brightness
- P7 Mel
- P8
- P5
X800m2 for:
- P7 FEL extending brightness
EDIT:
P8 (wrong) Sony Bravia A8H
P8 (optimal) Sony Bravia A8h
I don't know what to say... the image given by the wrong P8 seems even brighter and more enjoyable to me.
Enough.. I don't give up on understanding more
#8855 Post by RESET_9999 » Thu Sep 14, 2023 9:35 pm
Then your TV internal player is wrong.
It just make no sense that (2000 L1 + 1000nits BL) produce a brighter image than (1000 L1 + 1000 BL)
#8856 Post by RESET_9999 » Thu Sep 14, 2023 9:39 pm
I'll have a look but...
Last time I checked, LG TVs were downgrading multi-channel PCM to stereo. I even bought an expensive EARC adaptor for my AVR and still couldnot get better than 2.0 PCM audio from the TV.
Trees
#8857 Post by Trees » Thu Sep 14, 2023 10:20 pm
RESET_9999 wrote:
Tue Sep 12, 2023 7:07 pm
Trees wrote:
Tue Sep 12, 2023 7:00 pm
I don't follow. Are you saying The.Grand.Tour.S05E01/02.2023.2160p.AMZN.WEB-DL.DDP5.1.DoiVi.HBRID.P8 are MadVR generated? How do you know that? The plots say CM v4.0 Dolby Vision. Do you think they chose different L1 analysis tuning to achieve "10k nits"? Is it really 10k nits or is that decided by the pixel brightness relative to other pixel brightnesses? I really don't understand what you mean, I'm not sure how it correlates with my question, to be honest with you. I realise I have alot to learn, but I just don't understand what you mean. :(
The Grand Tour is not DV AFAIK.
Your file is DV is not original.
I'm aware. It's in HDR10 or HDR10+ only, because Amazon Prime. I'm just wondering how they're getting better results with the same algorithm. Their plot says it's CMv4.0 DV. I used CMv4.0 on the same input file, but got lesser results. I'm just wondering how that's possible because we're both using the same algorithm.
#8858 Post by RESET_9999 » Thu Sep 14, 2023 11:38 pm
Why do you think higher L1 is better?
I don't think the cmv40 L1 plot you posted was done with the Dolby algo. Min_pq is always 0 so either it was done with madvr or hdr10plus and most likely without L3.
the dovi script removes cmv4.0 when it generates from madvr or hdr10plus because I'm not sure if cmv4.0 metadata without a proper Level 3 is actually correct.
As explained before, there are many ways to get different L1. the new algo in cm_analyze can produce different L1 depending on the tuning you use.
In resolve, if you don't use cubic scaling, you get too high values that not a single retail DV movie uses.
thirdmoon
#8859 Post by thirdmoon » Fri Sep 15, 2023 5:12 am
DaVinci Resolve Studio 18.6
"Dolby Vision CM 4.0 L1 analysis with user-selected filtering support."
What does this mean?
Mrmorrison
#8860 Post by Mrmorrison » Fri Sep 15, 2023 6:58 am
Sorry my friend. You are right. I took an incorrect image.
Here is the correct comparison.
DV 8 (wrong) from your files:
DV8 (optimal) from your files:
Comparison slow pics
https://slow.pics/c/3a1kpalj
Here I don't find any differences even in the camera images. :roll:
jlpsvk
#8861 Post by jlpsvk » Fri Sep 15, 2023 10:05 am
Curious too... but i think it means Resolve has the new 2023 DoVi algo from now. :)
#8862 Post by RESET_9999 » Fri Sep 15, 2023 11:00 am
nice! looks like they updated the Dolby algo like in CM
great news thanks for sharing.
#8863 Post by RESET_9999 » Fri Sep 15, 2023 11:03 am
well I don't know. Are you using a phone to take those pictures?
if yes, you need a DSLR camera that can lock all the settings.
On a phone, there's always the exposure or ISO that remains dynamic making it almost impossible to make accurate comparisons..
Mrmorrison
#8864 Post by Mrmorrison » Fri Sep 15, 2023 11:19 am
I have this https://www.nikonusa.com/en/nikon-produ ... -b700.html
jlpsvk
#8865 Post by jlpsvk » Fri Sep 15, 2023 11:25 am
yes... it's there!!! :) Resolve 18.6
and it's freakin' fast... really don't know why cm_analyze is slowing down. :(
