MKV and Libredrive firmware flashing Help for - PIONEER External Blu-ray Drive BDR-XD08B
pandaboy
Post by pandaboy »
I intended to purchase the Pioneer Electronics BDR-XD07U to rip 4k bluray drives to my Jellyfin server, but it is unavailable on Amazon. I ended up buying the Pioneer External Blu-ray Drive BDR-XD08B instead. When I went to use MKV it said that this drive was not libre-drive compatible but wasn't enabled was running firmware 1.02. Now, I'm wondering if I should go through the process of returning it. How would I go about flashing the firmware on it? Any guides you guys would recommend?
OS device name: /dev/rdisk4
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number: CFDL300633UC
Firmware date: 2022-12-27
Highest AACS version: 63
Drive platform: Pioneer RS9330
Firmware version: GENE
Re: MKV and Libredrive firmware flashing Help for - PIONEER External Blu-ray Drive BDR-XD08B
Not possible fw is to new
You should return it and buy a flashed pioneer from a seller in your region
pandaboy
Post by pandaboy »
Thats a hefy list of options. What usb external drive would you personally recommend?
pandaboy wrote: Thu Sep 14, 2023 8:05 pm Thats a hefy list of options. What usb external drive would you personally recommend?
Any of the pioneers are good
