Demon Slayer rips episodes into one file
Keydisccandle
Post by Keydisccandle » Thu Sep 14, 2023 1:00 pm
I just bought Demon Slayer Mugen Train. MakeMKV accesses and reads the BD disk just fine but when it is time for me to select options (just before ripping), it only lists one file which leads to a single file for three episodes. I watched the video, VLC shows chapters, more than three chapters.
Any ideas?
Re: Demon Slayer rips episodes into one file
Post by d00zah » Thu Sep 14, 2023 1:43 pm
Keydisccandle
Post by Keydisccandle » Thu Sep 14, 2023 1:59 pm
Thank you.
Post by d00zah » Thu Sep 14, 2023 6:41 pm
Keydisccandle wrote: Thu Sep 14, 2023 1:59 pm Thank you.
You are most welcome.
Radiocomms237
Post by Radiocomms237 » Thu Sep 14, 2023 11:11 pm
How many segments are listed in the map for that single playlist (.mpls)?
If the episodes are each in separate transport streams (.m2ts files), you can rename the playlist file in the backup folder before opening the disc (I'd suggest simply adding an extension, so "00000.mpls" might become "00000.mpls.removed"). Do not deleted the file altogether as you may need it again, and playlists don't take up much HDD space anyway!
This will force MakeMKV to give you access to the individual episodes in .m2ts form.
That would save you having to split the combined file afterward, but you will lose any chapters that were in the playlist.
