Re: Pioneer firmware update February 2023
mickstaa wrote:
Tue Sep 12, 2023 10:40 am
Hello all,
Noob here. can someone point me in the direction to patched UHD enabling firmware for my drive:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.00
Serial number: SGDL000006WL
Firmware date: 2019-01-10
Highest AACS version: 19
Drive platform: RS8F01
Firmware version: 1.00/ID43
What model is it? If it is a S12UHT then it already is UHD enabled.
alminderson
Post by alminderson »
I'd like to transition my LibreDrive status from Possible, not yet enabled to Enabled.
Running MakeMKV v1.17.4 on macOS Ventury 13.5.2:
Product: BD-RW BDR-XS07U
Revision: 1.03
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 655
Firmware version: ID05
My goal here, really, is just to remove the 2x speed limit for archiving my discs, and achieve the drive's 6x max speed as advertised. If LibreDrive isn't what I'm looking for to achieve that, I'd appreciate any advice or links.
Out of luck since your firmware is newer than Dec. 2012. Wait patiently for a fix by Mike.
Coopervid wrote:
Wed Sep 13, 2023 6:41 pm
You need to download the Pioneer Tool from their website to change options.
randomgeeza
Post by randomgeeza »
Is there a tool that works on macOS. I wouldn't mind a looks if there is...
randomgeeza wrote:
Wed Sep 13, 2023 6:59 pm
A tool for what?
https://pioneer.jp/device_e/product-e/i ... iveUtility
InfinityX
Post by InfinityX »
We have a new official pioneer firmware 1.05. Do we have anything new with this new firmware?
BDR-S13U-X / S13E-X / S13C-X
ver. change point
1.05 Added a new function "Damage Prevention mode for music CD" Improved operational stability
https://pioneer.jp/cgi-bin/device/downl ... W105EU.exe
Post by SamuriHL »
More crap to prevent LibreDrive from working. Leave it alone.
TeddyRaspin
Post by TeddyRaspin »
1.05 fw version, as well as 1.04, upgrades also kernel part.
mrcontento
Post by mrcontento »
arremelle wrote:
Mon Aug 14, 2023 1:36 pm
I have the same drive and situation as Asian wolf. I just got my drive from Amazon yesterday and I can read blu-rays just fine but not UHD.
MakeMKV is connected to the internet and I have been using it also for many years with DVD/Blu-rays no problem.
Replying so I can see any updates. Thanks in advanced for the support.
Same here .... waiting on solution for 1.03
palindromico
Post by palindromico »
Imagine that I had the player working and with the right FW, and (not knowing it, my fault) I updated it...
I'm calling myself an idiot every other day...
hydroptix
Post by hydroptix »
Would it be possible to put a warning into MakeMKV itself telling people not to upgrade firmware on Pioneer drives?
Probably currently watching Baby Driver on bluray, because all the streaming versions suck.
g0th1ckn1ght
Post by g0th1ckn1ght »
I also stupidly upgraded my firmware on my BDR-XS07TUHD today to version 1.03 and I can no longer rip my UHD's. I went and bought a brand new one and it came with the dreaded 1.03 firmware, which I tried to return and got told to bad so sad the drive works.
Is this being worked on\can this be fixed or do I need to buy a different UHD drive?
ItsOdysseus
Post by ItsOdysseus »
Yep, i believe this is actively being worked on. Either an update to MKV for 1.03 or a way to safely downgrade software.
