Vellichroma9 wrote:
Tue Sep 12, 2023 8:12 pm
Thanks for the heads up about using DaVinci Resolve. I'm going to delve into it and see what I can make of it.
Thanks again.
There's a resolve SDR to HDR preset in my script tutorial folder.
It converts rec709 SDR to rec2020 HDR 100nits and then you have to go shot by shot and play with the HDR settings (and colors if you wish).
Vellichroma9
Post by Vellichroma9 »
RESET_9999 wrote:
Tue Sep 12, 2023 8:33 pm
Thanks again.
That's wonderful, I'll look into it. Thanks again.
Mrmorrison
Post by Mrmorrison »
RESET_9999 wrote:
Tue Sep 12, 2023 11:06 am
look at the comparisons in the red section that says:
Can only be played on a FEL device and can't be converted to P8 without baking FEL into EL
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Thank you. I notice a great work behind all this, congratulations.
Forgive my ignorance once again. Looking at the comparison images I notice a very minimal difference in terms of brightness. As I was told a few messages later, is brightness the characteristic that is left by converting FEL to 8? Or do you also lose overall image quality?
Mrmorrison wrote:
Wed Sep 13, 2023 9:34 am
sometimes yes
https://slow.pics/c/UnrLCYuv
https://slow.pics/c/TR4EhPpl
https://slow.pics/c/9UuZ2ruK
Mrmorrison
RESET_9999 wrote:
Wed Sep 13, 2023 11:04 am
sometimes yes
Thank you!
Mrmorrison
So, the point is this:
I'm asking what I lose if I convert the FEL to 8.1 for a reason. The reason is that my TV, unfortunately, is PLAYER LED and therefore leaves the "dirty work" to my x800M2. However, the difference that I notice when I watch a film with Dolby vision played directly from the TV is notable compared to when I play the same film on the player.
So I always prefer to watch my films directly from the TV (Kodi mod, emby.. in short, app with ExoPlayer which manages Dolby Vision perfectly).
Until now I used x800m2 only for FEL (the only mode that my TV does not support). But, for simple curiositym I started converting FEL to 8 to find differences between the FEL reproduced by the player and profile 8 reproduced by the TV. The result is that, for my taste, the TV (profile 8.1) always wins against the player (profile 7 FEL). More color and more brightness and objectively a more beautiful image.
In my situation, therefore, am I right to convert FEL to 8 to be able to use dolby vision directly from the TV compared to using dolby vision FEL (darker, less colorful) from x800m2?
I hope I was clear. Forgive my English :?
Mrmorrison wrote:
Wed Sep 13, 2023 5:40 pm
p7 to p8 from a movie that expands brightness is wrong and worse than HDR10. The dv metadata are meant to work with the FEL brightness only and the P8 conversion will look much darker than intended.
watch this comparison:
https://www.youtube.com/watch?v=VObky4peBXE
Also, on the x800m2/x700 player-led mode, RPU has no effect with 1000nits movies.
Mrmorrison
This is why I'm confused. Because for me it's the opposite. The P8 film (converted - reproduced directly from the TV, therefore "LED TV") is brighter than the same film in P7 FEL (from x800m2, therefore "LED player"). Maybe I persist in not understanding something.
Look here:
FAST X - FEL - X800M2
FAST X (EX FEL) CONVERTED TO P8 - SONY BRAVIA A8H
Mrmorrison
Ok, tomorrow I'll do the same test with this film.
Thank you
mad83
Post by mad83 »
My LG OLED55B7V is not able to play any of those.
Is there anything what i can do to be able to watch them?
mad83 wrote:
Thu Sep 14, 2023 5:40 am
I don't know. You may have to mux them to MP4?
BadSector81
Post by BadSector81 »
Hi RESET_9999!
I used 1.9.2.6. beta 8-7-1 Dolby CM_offline (export SDR 100nits trim pass). My input was a 4K file but I got 2K output. I there any change to get 4K SDR MOV? Thanks!
BadSector81 wrote:
Thu Sep 14, 2023 12:55 pm
Hi RESET_9999!
line 117
set downscale=NO
PS expect the mov file to be huge 500gb +
BadSector81
RESET_9999 wrote:
Thu Sep 14, 2023 12:59 pm
Hi RESET_9999!
line 117
set downscale=NO
Nice, thank you so much!
