Mrmorrison
#8821 Post by Mrmorrison » Tue Sep 12, 2023 10:21 am
Claiming that a P7 FEL is the same if you convert it to a P8 is wrong, I understand.
Can you explain to me what exactly is lost from this operation?
#8822 Post by RESET_9999 » Tue Sep 12, 2023 11:05 am
Trees wrote: Tue Sep 12, 2023 9:00 am Does anyone know if it's possible to get 10k nit with CM v4.0 like these?
I'm asking because whatever mastering display I choose with 3-1 (Professional CM v4.0 Dolby Algo) I get lesser results, maximum 1k, 2k or 4k nits. 10k nits doesn't seem available. Is there a reason for this or?
Do the guys above have access to tools we don't or does Dovi_scripts just not allow 10k nits (yet)?
The metadata cannot be 10k if the content is not 10k. The Algo measures each pixel's brightness and produces metadata accordingly.
#8823 Post by RESET_9999 » Tue Sep 12, 2023 11:06 am
Mrmorrison wrote: Tue Sep 12, 2023 10:21 am Claiming that a P7 FEL is the same if you convert it to a P8 is wrong, I understand.
look at the comparisons in the red section that says:
Can only be played on a FEL device and can't be converted to P8 without baking FEL into EL
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Trees
#8824 Post by Trees » Tue Sep 12, 2023 4:55 pm
RESET_9999 wrote: Tue Sep 12, 2023 11:05 am
But according to the plot, they are 10k nits:
Even though the original plots are like this:
How are they achieving 10k nit peaks with a CM v4.0 conversion (CM v4.0 according to the plots)? I've tied to replicate it but the plots don't go above 4k nits. Here are the MediaInfo outputs:
Complete name                            : /media/user/WD 1 TB/Videos/The Grand Tour/Series 5/S05E01 - A Scandi Flick missing chapters 2160p HDR10p Amazon Prime Web-DL.mkv
File size                                : 10.8 GiB
Duration                                 : 1 h 39 min
Overall bit rate                         : 15.4 Mb/s
Movie name                               : A Scandi Flick
Encoded date                             : UTC 2023-09-07 15:54:25
Writing application                      : mkvmerge v75.0.0 ('Goliath') 64-bit
Writing library                          : libebml v1.4.4 + libmatroska v1.7.1
Video
Format profile                           : Main 10@L5@Main
HDR format                               : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate                                 : 14.8 Mb/s
Frame rate                               : 25.000 FPS
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.071
Stream size                              : 10.3 GiB (96%)
Title                                    : 2160p HDR10+ Amazon Prime Web-DL
Maximum Content Light Level              : 999 cd/m2
Maximum Frame-Average Light Level        : 745 cd/m2
Complete name                            : /media/user/WD 1 TB/Videos/The Grand Tour/Series 5/S05E02 - Eurocrash missing chapters 2160p HDR10p Amazon Prime Web-DL.mkv
File size                                : 11.5 GiB
Duration                                 : 1 h 46 min
Movie name                               : Eurocrash
Encoded date                             : UTC 2023-09-07 16:01:55
Video
Stream size                              : 11.0 GiB (96%)
Maximum Frame-Average Light Level        : 680 cd/m2
What's going on here?
#8825 Post by RESET_9999 » Tue Sep 12, 2023 5:47 pm
Trees wrote: Tue Sep 12, 2023 4:55 pm But according to the plot, they are 10k nits:
Well you're comparing madvr vs dolby tunning 1.
You have control of the L1 tunning at line 95 in the bat file, change it to 0. default is 1 and the best tunning.
if you use the old legacy mode (0), this will probably get you that frame at 10knits but you shouldn't do that.
:: choose the L1 analysis tuning... Choices are: (old=0 - Most Highlight Detail/Most Mapping=1(default) - More Highlight Detail/More Mapping=2 - Balanced=3 - Less Highlight Detail/Less Mapping=4 - Least Highlight Detail/Least Mapping=5
set L1_Tuning=1
Trees
#8826 Post by Trees » Tue Sep 12, 2023 7:00 pm
RESET_9999 wrote: Tue Sep 12, 2023 5:47 pm Well you're comparing madvr vs dolby tunning 1.
set L1_Tuning=1
I don't follow. Are you saying The.Grand.Tour.S05E01/02.2023.2160p.AMZN.WEB-DL.DDP5.1.DoiVi.HBRID.P8 are MadVR generated? How do you know that? The plots say CM v4.0 Dolby Vision. Do you think they chose different L1 analysis tuning to achieve "10k nits"? Is it really 10k nits or is that decided by the pixel brightness relative to other pixel brightnesses? I really don't understand what you mean, I'm not sure how it correlates with my question, to be honest with you. I realise I have alot to learn, but I just don't understand what you mean. :(
#8827 Post by RESET_9999 » Tue Sep 12, 2023 7:07 pm
Trees wrote: Tue Sep 12, 2023 7:00 pm I don't follow. Are you saying The.Grand.Tour.S05E01/02.2023.2160p.AMZN.WEB-DL.DDP5.1.DoiVi.HBRID.P8 are MadVR generated? How do you know that? The plots say CM v4.0 Dolby Vision. Do you think they chose different L1 analysis tuning to achieve "10k nits"? Is it really 10k nits or is that decided by the pixel brightness relative to other pixel brightnesses? I really don't understand what you mean, I'm not sure how it correlates with my question, to be honest with you. I realise I have alot to learn, but I just don't understand what you mean. :(
The Grand Tour is not DV AFAIK.
Your file is DV is not original.
Vellichroma9
#8828 Post by Vellichroma9 » Tue Sep 12, 2023 7:10 pm
Hey guys,
Hope you're good. I'm working on a project and was wondering if you know of a way to extract the HDR10 stream from a video file and then inject it into another video file. Is there a go-to tool or DovI_Scripts workflow that people use for this?
I would appreciate any tips or advice!
Thanks.
#8829 Post by RESET_9999 » Tue Sep 12, 2023 7:16 pm
Vellichroma9 wrote: Tue Sep 12, 2023 7:10 pm Hey guys,
Thanks.
No, HDR must be graded otherwise it will be the same 100nits video in an HDR container.
Vellichroma9
#8830 Post by Vellichroma9 » Tue Sep 12, 2023 7:31 pm
RESET_9999 wrote: Tue Sep 12, 2023 7:16 pm
Thanks.
Hey,
Thanks for the insight on the HDR10 streaming process. It got me thinking — could I possibly do this using Dolby Vision instead? I've heard that the madVR workflow might allow for the generation of an HDR video from an SDR source with the right brightness characteristics, or is that only from HDR10 to HDR10+?
Just to recap, I have two versions of the same video file — one in 1080p which contains HDR10/Dolby Vision content, and a 4K one that is in SDR. My ultimate goal here is to create a 4K file that has the proper HDR or Dolby Vision characteristics leveraging the data from the 1080p file if necessary.
Obviously if the HDR must be graded, it probably involves a specialized process that generally requires professional tools and expertise beyond the scope of what I might be able to do, but i thought I'd still shoot the question. Do you think this is possible, and do you have any advice or resources that might help me in achieving this?
Thanks again for your help!
#8831 Post by RESET_9999 » Tue Sep 12, 2023 7:40 pm
The SDR generated DV would be capped at 100nits so I'm not sure what would be the point of doing that.
Yes, it can be done in Davinci Resolve but it requires experience and time.
It takes me about 2h to manually convert an SDR movie to HDR shot by shot.
Vellichroma9
#8832 Post by Vellichroma9 » Tue Sep 12, 2023 8:12 pm
Ah, gotcha. Makes sense that the brightness would be capped given the SDR's nit limitations. Seems like it might not give the full benefits of HDR then.
Thanks for the heads up about using DaVinci Resolve. I'm going to delve into it and see what I can make of it.
Thanks again.
#8833 Post by RESET_9999 » Tue Sep 12, 2023 8:33 pm
Vellichroma9 wrote: Tue Sep 12, 2023 8:12 pm Thanks for the heads up about using DaVinci Resolve. I'm going to delve into it and see what I can make of it.
Thanks again.
There's a resolve SDR to HDR preset in my script tutorial folder.
It converts rec709 SDR to rec2020 HDR 100nits and then you have to go shot by shot and play with the HDR settings (and colors if you wish).
Vellichroma9
#8834 Post by Vellichroma9 » Tue Sep 12, 2023 8:38 pm
RESET_9999 wrote: Tue Sep 12, 2023 8:33 pm
Thanks again.
That's wonderful, I'll look into it. Thanks again.
Mrmorrison
#8835 Post by Mrmorrison » Wed Sep 13, 2023 9:34 am
RESET_9999 wrote: Tue Sep 12, 2023 11:06 am
Thank you. I notice a great work behind all this, congratulations.
Forgive my ignorance once again. Looking at the comparison images I notice a very minimal difference in terms of brightness. As I was told a few messages later, is brightness the characteristic that is left by converting FEL to 8? Or do you also lose overall image quality?
