Upgraded computer. MakeMKV stopped working
faustag
#1 Post by faustag » Tue Sep 12, 2023 1:20 am
upgraded from a threadripper to an epyc. completely new machine. New Os install. can't rip any blurays anymore. I'm sure this must be some configuration thing.
                   -`                    sirus@neuromancer
                  .o+`                   -----------------
                 `ooo/                   OS: Arch Linux x86_64
                `+oooo:                  Host: MZ32-AR0-00 0100
               `+oooooo:                 Kernel: 6.5.2-arch1-1
               -+oooooo+:                Uptime: 2 hours, 10 mins
             `/:-:++oooo+:               Packages: 1573 (pacman)
            `/++++/+++++++:              Shell: bash 5.1.16
           `/++++++++++++++:             Resolution: 3840x2160, 3840x2160
          `/+++ooooooooooooo/`           DE: Xfce 4.18
         ./ooosssso++osssssso+`          WM: Xfwm4
        .oossssso-````/ossssss+`         WM Theme: Default
       -osssssso.      :ssssssso.        Theme: Adwaita [GTK2/3]
      :osssssss/        osssso+++.       Icons: elementary [GTK2], Adwaita [GTK3]
     /ossssssss/        +ssssooo/-       Terminal: xfce4-terminal
   `/ossssso+/:-        -:/+osssso+-     Terminal Font: Monospace 12
  `+sso+:-`                 `.-/+oso:    CPU: AMD EPYC 7473X (48) @ 2.800GHz
 `++:.                           `-/+/   GPU: AMD ATI Radeon RX 7900 XT/7900 XTX
 .`                                 `/   Memory: 11669MiB / 515648MiB
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO1M2QI2033
Highest AACS version: 76
Firmware version: 1.03
Disc Information
Label: JOHN_WICK
Timestamp: 2016-11-17 14:50:26
Protection: AACS2.0/C v61
Data capacity: 62.7 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.17.4 linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Re: Upgraded computer. MakeMKV stopped working
#2 Post by Billycar11 » Tue Sep 12, 2023 8:11 pm
Your have a pass through issue your drive is not receiving libredrive commands are you using a docker image?
If so install it natively.
Or if it is then what drive do you have I only see 1.03 fw I'm. Guessing BU40N?
faustag
#3 Post by faustag » Wed Sep 13, 2023 6:41 am
No I'm not using a docker image. all native.
yes it's a BU40N
Revision: 1.03
#4 Post by Billycar11 » Wed Sep 13, 2023 7:59 pm
yes it's a BU40N
Revision: 1.03
Then flash it to 1.00 and it will work
faustag
#5 Post by faustag » Thu Sep 14, 2023 12:08 am
That did work!
I'm really confused I thought 1.03 was the one that was ok, and I was ripping blurays on my old machine so I'm double confused, but now I'm on 1.00 and no issues.
Thx
#6 Post by Billycar11 » Thu Sep 14, 2023 6:00 am
mike admin wrote:
