Need Title selection string syntax for 1984 Dune Extended Edition
Beastmaster451
Help! I need the "Title selection string syntax" for 1984 Dune Extended Edition. Can anyone help?
Re: Need Title selection string syntax for 1984 Dune Extended Edition
What happens when you open discs in a regular way? Any error log?
ilkaplan
I am having a problem ripping side B of the Dune Extended edition Steelbook disc.
I am in the process of manually ripping the disc now and am saving the log as an example, but basically it says something like this
"Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '4414355456'
DEBUG: Code 1073741829 at mx"t@Ld9Mn[*I"irsv:213131502"
Is there any way I can skip over that section of the disc to complete the rip?
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '4414355456'MakeMKV insists on no errors during the rip. With an error, the rip isn't successful.
