axeyou
Post by axeyou » Mon Sep 11, 2023 4:04 am
RESET_9999 wrote:
Sat May 14, 2022 12:57 pm
*** I think I found an issue with the x800m2:
1- DTS-HD 2.0 plays only as lossy DTS (core)
Is this bug still present with the X800M2? I tried playing a DTS-HD MA 2.0 track and my receiver reported DTS-HD MA, not DTS. However, I have no clue if the X800M2 is doing something weird like wrapping the lossy DTS core in a DTS-HD MA container on the fly. How did you find this bug? Is there a test file with a silent core to easily verify what is being played?
2- DTS-HD 7.1 seems to always be out of sync about 2 frames (83MS) but strangely DTS-HD 5.1 is fine.
I don't see this bug listed on the DoVi Playback Devices sheet. Has it been fixed?
sw5163
Post by sw5163 » Mon Sep 11, 2023 7:52 am
EncodeThis420 wrote:
Sun Sep 10, 2023 6:36 pm
Why do none of the encoders seem to care that there may be brightness grading differences between the p5 and hdr10 streams?
Yeah, and since P5 RPU needs to be extracted to hybrid P8.1 either way, why they just don't bother to release the original P5 file?
The chinese group you are referring to only releases itunes p5s?
I don't know, they seem to have a PT website, I can't play with PT, all I grab are their BT leaks.
I haven't seen them release P5 other than itunes source, but maybe because I'm not paying very much attention.
Not from any other source?
I'm not as knowledgeable as you guys here, there is another streaming service provides P5? Movies Anywhere?
Don't itunes p5s have screwed up colors?
Sometimes they release a V2 and color seems fine. But again, there might be other problem as I said above, so I'm still looking for more trusted group. Btw, does DVSUX still exist after the shutdown of rarbg? I really miss their releases.
Spider-Man.Across.the.Spider-Verse.2023.2160p.iTunes.WEB-DL.DDP.5.1.Atmos.DV.H.265-DreamHD
Spider-Man.Across.the.Spider-Verse.2023.V2.2160p.iTunes.WEB-DL.DDP.5.1.Atmos.DV.H.265-DreamHD
Post by RESET_9999 » Mon Sep 11, 2023 11:09 am
it might be a thing with my AVR. The osd reports only DTS while with 5.1/7.1 tracks it reports DTS-HD.
It could also be related to the network playback , I don't think I ever tried via USB.
I have a NAS with many drives (not in raid) and I noticed that when I watch something on the x800m2 and if someone in my house wake up another drive in my NAS, it will freeze my movie for a few second and resume with OOS audio.
If I just pause/resume, it fixes it.
So that might be what I noticed back then and it just randomly happened with DTS-HD 7.1 tracks because it's working great now.
Post by RESET_9999 » Mon Sep 11, 2023 11:12 am
Mrmorrison wrote:
Sun Sep 10, 2023 8:56 am
Hi everyone!
Lately I've been imagining videos with profile 8 that played on my Sony TV have some lowering of the Frame.
So I went looking in the DoviScript menus to find something that could fix this very annoying problem.
The function is there! And it's the fps fix (2-1-3).
However, I am curious to know if this problem is caused by something wrong on the part of whoever injects profile 8 into the video.
Can you tell me something?
Thank you!
EDIT:
By any chance, is there a way to understand if the frame needs to be adjusted even before watching the video?
I'm not sure how changing the fps would make the file works on Sony TVs. I thought they only supported P5?
If you get the older version of my script, there were workflows that could make fake ''p5'' file from p8 that should works.
Mrmorrison
Post by Mrmorrison » Mon Sep 11, 2023 11:20 am
My Sony TV plays all profiles up to 7 Mel from mkv. More than stable. Lately I've been taking profile 8 material (which didn't have any problems until some time ago) in which I notice fluidity problems. Problems that are totally solved with your script, running the "fix frame".
Only 20% of videos with Dolby Vision 8, from my web source, have this problem (with my TV, maybe with other devices it goes smoothly) and I was wondering if it was a problem of the person who injects Dolby Vision, maybe he made a mistake some settings.
Post by RESET_9999 » Mon Sep 11, 2023 11:23 am
ha I see.
Then the problematic files are most likely P8 hybrid from iTunes...
Those webdl are missing the framerate bitstream information and this is what the script fixes.
Mrmorrison
Post by Mrmorrison » Mon Sep 11, 2023 11:26 am
ha I see.
In fact, now that you mention it, the problem showed up on all episodes of the Foundation, AppleTV series
EncodeThis420
Post by EncodeThis420 » Mon Sep 11, 2023 1:57 pm
I saw a few people say that DVSUX is no longer doing releases. I can't confirm that though. I have no idea. And yea, it's crazy that they don't also release the P5 versions since they're required for P8 conversion lol.
thirdmoon
Post by thirdmoon » Mon Sep 11, 2023 4:46 pm
https://slow.pics/c/eUPDkTHU
Barbie 2023
Why scene cuts different in HDR10+ and DV version?
Post by RESET_9999 » Mon Sep 11, 2023 5:10 pm
Barbie 2023
I'm not sure but...
In Dolby vision, sometimes the flashes (single frame) can have their own scene cut which doesn't seem to cause any problem at playback (I tested that with my own rpu).
In HDR10plus, I read somewhere that the metadata can only change at a real scene cut or otherwise, it can cause issues.
skull88
Post by skull88 » Mon Sep 11, 2023 5:44 pm
Barbie 2023
I'm not sure but...
More logistically, the HDR10+ could have been provided by different source for the streaming platform or requested for streaming only, as it is likely upcoming UHD BD will only have DV from Warner Bros.
quietvoid
Post by quietvoid » Mon Sep 11, 2023 7:48 pm
It's usually HDR10+ that has more random changes in the metadata, like flashes.
Dolby Vision always relies on the shots and flashes don't cause new metadata because the shots are predetermined when editing/grading.
I don't think HDR10+ actually lets you align everything to shots, the process is too automated.
Post by RESET_9999 » Mon Sep 11, 2023 8:11 pm
Well, I have definitely seen flashes as a single shot in retail DV source...
The Bad Guys animation movie is one I remember because it confused me when I did my P8 hybrid remux.
axeyou
Post by axeyou » Mon Sep 11, 2023 8:16 pm
Interesting. I’m playing through network as well. Both the X800M2 and my AVR report DTS-HD MA on a 2.0 track.
Yes. I’ve seen that as well on my own rip of Arrow’s Cinema Paradiso DV UHD disc.
skull88
Post by skull88 » Mon Sep 11, 2023 8:35 pm
Yeah, I've also seen that. I'm guessing (some? many?) DoVi shot lists are at least initially coming from an automatic algo pass (especially since v4.0 from Dolby), as it would save anyone doing the grading a huge amount of time/labour, even if they do a second manual pass after to delete/add further, and they either just leave the very short "flash" shots in or don't even notice them, lol.
