obviouslytom
Re: SDFtool Flasher
Post by obviouslytom » Thu Sep 07, 2023 9:54 pm
MartyMcNuts wrote: Thu Sep 07, 2023 7:27 am
obviouslytom wrote: Wed Sep 06, 2023 10:31 pm Hello everyone,
I have been trying to follow the guide and flash my LG drive to enable libredrive, however I have been failing at it. I keep receiving an error code of: 0x82052603
https://drive.google.com/file/d/1Rdj_jo ... drive_link
I have been trying to flash it to the following firmware: DE_LG_WH16NS40-NS50_1.02.bin
Here is a screenshot of MakeMKV:
https://drive.google.com/file/d/1k3EPKb ... drive_link
I have read other responses that said to flash it to DE_LG_WH16NS60_1.02_MK.bin first, then use the one above, but nothing works. Does anyone have any idea what I can do to make it work? I have had this drive since 2020 (with what looks like a firmware date of 1/4/2019) and I have a few UHD discs that I want to rip for my Plex server.
Copy & paste the MakeMKV info for your drive.
OS device name: E:
Current profile: DVD-ROM
Product: BD-RE WH16NS40
Revision: 1.04
Serial number: KLKJC354855
Firmware date: 2119-01-04 13:48
Highest AACS version: 78
Re: SDFtool Flasher
Post by Billycar11 » Fri Sep 08, 2023 1:20 am
obviouslytom wrote: Thu Sep 07, 2023 9:54 pm
OS device name: E:
Revision: 1.04
do not use enc when flashing and it should work
obviouslytom
Re: SDFtool Flasher
Post by obviouslytom » Fri Sep 08, 2023 9:29 pm
Billycar11 wrote: Fri Sep 08, 2023 1:20 am
OS device name: E:
Revision: 1.04
It doesn't matter if I try it with encryption turned on or off, I keep getting an error of "command produced erro code 0xff05c103". I have tried the firmware "DE_LG_WH16NS40-NS50_1.02" and "DE_LG_WH16NS40_1.01" and nothing works. I have even tried flashing to WH16nS60 as someone else was able to and nothing.
JagStinker
Re: SDFtool Flasher
Post by JagStinker » Fri Sep 08, 2023 10:45 pm
I have a Verbatim 4K ultra HD External Slimline writer. Specs as follow:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: CGDL109907WL
Firmware date: 2020-06-15
Which firmware should I choose?
Re: SDFtool Flasher
Post by Billycar11 » Sat Sep 09, 2023 1:31 am
obviouslytom wrote: Fri Sep 08, 2023 9:29 pm
OS device name: E:
Revision: 1.04
well those are the wrong fw maybe you should follow the guide see below
doulikescarymovies
Re: SDFtool Flasher
Post by doulikescarymovies » Sat Sep 09, 2023 6:09 am
Does it work on Mac?
obviouslytom
Re: SDFtool Flasher
Post by obviouslytom » Sat Sep 09, 2023 3:52 pm
Billycar11 wrote: Sat Sep 09, 2023 1:31 am
So then what is the right one?
Re: SDFtool Flasher
Post by Billycar11 » Sat Sep 09, 2023 3:54 pm
obviouslytom wrote: Sat Sep 09, 2023 3:52 pm
Read the guide or buy an automated flasher from me or Marty
Re: SDFtool Flasher
Post by dcoke22 » Sat Sep 09, 2023 4:04 pm
obviouslytom wrote: Sat Sep 09, 2023 3:52 pm So then what is the right one?
If you look at the Flashing Guide, you'll see a section titled 'Recommended Firmware to flash for MakeMKV:'
In there, you'll see:
'WH16NS40 on any Firmware directly to > WH16NS60 1.02MK'
The open secret of LG desktop drives is they're all the same hardware on the inside, just different firmware enabling or disabling 'features'. Through empirical study over the years, it has been determined that the 16NS60 1.02 firmware is the best of the bunch for LG desktop drives. The MK version is what enables LibreDrive.
obviouslytom
Re: SDFtool Flasher
Post by obviouslytom » Sat Sep 09, 2023 4:46 pm
dcoke22 wrote: Sat Sep 09, 2023 4:04 pm
Right after I made that post, I came across this site and it had exactly what I needed.
https://coolaj86.com/articles/how-to-ri ... ibredrive/
https://www.makemkv.com/download/mk-fir ... 200720.zip
After getting the 1.05 firmware, libredrive was enabled and I am ripping my Event Horizon 4k disc.
Riker99
Re: SDFtool Flasher
Post by Riker99 » Sat Sep 09, 2023 11:26 pm
downlod sfdtool, window 11 dont recognize lg wh14ns40 cdrom drive.
will_lawrence1966
Re: SDFtool Flasher
Post by will_lawrence1966 » Sun Sep 10, 2023 9:16 pm
Hi there! I have a Matshita BD-RE UJ260AF Bluray drive (Internal "laptop" drive in Desktop [HP230Z]) and don't know what to flash it to. I dont even know how old it is cause I dont want to pull it out (which would take hours since i have tons of external USB drive connected along with other peripherals. I am running Windows 11 (not sure which build). Thanks...
Panda04
Re: SDFtool Flasher
Post by Panda04 » Mon Sep 11, 2023 2:52 pm
I'm having the same issue. Windows 11 see the drive but SDFlasher Tool doesn't not show it in the drive popup.
The drive is an Ausus BW-16D1HT.
Any suggestions on getting this to work?
TIA
Re: SDFtool Flasher
Post by MartyMcNuts » Mon Sep 11, 2023 8:04 pm
Panda04 wrote: Mon Sep 11, 2023 2:52 pm I'm having the same issue. Windows 11 see the drive but SDFlasher Tool doesn't not show it in the drive popup.
TIA
You must have MakeMKV installed in the default location which should be: C:/Program Files (x86)/MakeMKV.
smallfat
Re: SDFtool Flasher
Post by smallfat » Wed Sep 13, 2023 3:22 am
With updated firmware, may I burn BDR XL disc?
Regards
