LibreDrive for Pioneer drives
MrEJ42 wrote: Sat Sep 09, 2023 1:26 pm
Coopervid wrote: Sat Sep 09, 2023 10:07 am
MrEJ42 wrote: Fri Sep 08, 2023 10:10 pm
Meh. I discovered that my internal drive on my old PC works perfectly, so I'm in no rush for Pioneer support now.
Read your PM.
You're confusing me with someone else. I have a BDR-XD08U, for which no solution currently exists.
Yes it does if your firmware is older than Dec. 2022. But I assumed you have 209. Let me know the firmware date of your XD08U fits or if it is among tha drives that can't be fixed yet.
MrEJ42
Post by MrEJ42 »
Coopervid wrote: Sat Sep 09, 2023 5:29 pm
Read your PM.
It isn't. It has the dreaded new firmware.
nohairbear
Post by nohairbear »
Thanks for the PM, Coopervid. I'm so new I'm not allowed to PM yet. Would you mind pointing me to the particular file I need? Thanks.
Check you PM.
miba78 wrote: Mon Sep 04, 2023 8:22 pm
Tom886 wrote: Mon Aug 21, 2023 2:17 am The BDR-209EBK is an awesome drive and absolutely makeMKV safe, incl FW1.54.
You can downgrade from v1.54 to previous versions (did it myself) and also crossflash to the BDR-211 v1.53 to read UHD discs (again, done by myself).
One important thing, don't crossflash to v1.54 of the BDR-211, you lose downgrade, crossflash, lose the ability to play UHD with a Leawo Blu-ray player (according to a different forum, other programs may be also affected) and lose the "safety" of makeMKV.
Hi Tom886,
which tool did you use to flash the BDR-209EBK to BDR-211, please?
Check your PM.
Tom886
Post by Tom886 »
miba78 wrote: Mon Sep 04, 2023 8:22 pm Hi Tom886,
Sorry, I was absent for a few days, so didn't see your message.
I believe you got help already, and I have to admit, I am not sure whether it is allowed to share links to another forum.
But I can tell you, it's available on a Polish forum, however, not public.
Tom
ant.one
Post by ant.one »
Hello, used to read BD on my home player, but it died a few months ago.
Found out about libre drive and was able to read some of my BD movies on my computer with a BDR-S09 (firmware 1.54 from 2020).
Is there a way to crossflash it to be able to read UHD discs and movies (libredrive seems to see it as a BDR-209) ?
Informations lecteur
Nom du lecteur SE : H:
Fabricant : PIONEER
Produit : BD-RW BDR-S09
Révision : 1.54
Numéro de série : NEDL009445WL
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 76
Drive platform: RS8600
Firmware version: 1.54/ID43
nohairbear
Coopervid wrote: Mon Sep 11, 2023 5:03 pm Check you PM.
Thank you for the assistance Coopervid!
ant.one wrote: Thu Sep 14, 2023 12:29 pm Hello, used to read BD on my home player, but it died a few months ago.
Fabricant : PIONEER
Révision : 1.54
Email me your info for a flasher
ant.one
Post by ant.one »
Billycar11 wrote: Thu Sep 14, 2023 7:42 pm
Thank you.
Thanks from Tom's tips, I was able to reach pl forum. BDR-S09 can indeed be flashed to BDR-211 firmware. I can now enjoy my UHD discs.
I'm happy cause the player is rather silent.
Tried a more recent USB slim drive, but it was so loud I couldn't enjoy movies. No need to seek another player anymore. Thanks makemkv team
seanfletcher255
Post by seanfletcher255 »
PIONEER_BD-RW___BDR-212U_1.04_CEDL007031WL
PIONEER_BD-RW___BDR-212U_1.04_CCDL006974WL
PIONEER_BD-RW___BDR-212U_1.04_CEDL007036WL
Those are my drives that do not yet support the libreDriveMode
wildcat_betamax
Post by wildcat_betamax »
This is my first post here on the forum. I tried to do as much research as possible before reaching out, but can you please help me confirm what I believe to be true?
I have a Pioneer BD-RW BDR-X13U drive. I have been unable to rip 4K UHD discs yet - because from what I gather my "LibreDrive" is not yet enabled. DVD and BD rips work fine. I purchased it in May 2023. Below is the info shown in the MakeMKV app for me:
OS device name: /dev/rdisk4
Manufacturer: PIONEER
Product: BD-RW BDR-X13U
Revision: 1.03
Serial number: CBDL000152UC
Firmware date: 2022-12-12
Highest AACS version: 68
Firmware version: ID29
Disc Information
Label: CASINO
Timestamp: 2019-07-09 16:44:17
Protection: AACS2.0/C v68
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Am I out of luck because this drive's firmware is on v1.03 (and the firmware date is 2022-12-12)? Is there anything I can do with this drive at the moment to be able to rip 4K UHD discs?
Thanks for your help!
-wildcat
wildcat_betamax wrote: Sun Sep 17, 2023 8:03 pm Hello,
-wildcat
Sorry nothing can be done right now we have to wait for libredrive v2 for pioneers
DreckSoft
Post by DreckSoft »
I do have this drive:
Product: BD-RW BDR-S12
Revision: 1.02
Serial number: AKDL002802WL
Firmware date: 2022-03-09
Highest AACS version: 75
Firmware version: ID45
I thought the firmware should be old enough but it does not read any UHD disc. It won't even recognize that here is a disc in the drive. However, it will burn BD-XL.
Any hints? Unfortunately the forum does not allow a search for BDR-S12, so I might have missed something.
DreckSoft wrote: Wed Sep 20, 2023 11:01 am I do have this drive:
Revision: 1.02
thats a non UHD model do not update though
email me see below i may be able to help.
