Can't rip 4K Edge of Tomorrow
Mitchco
#1 Post by Mitchco » Fri Sep 08, 2023 7:09 pm
Hello, new to this, so maybe someone can spot the issue. Drive I am using:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: BLDL007676UC
Firmware date: 2022-10-24
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8E21
Firmware version: 1.02/ID05
Disc Information
Label: EDGE_OF_TOMORROW
Timestamp: 2022-05-09 20:13:50
Protection: AACS2.0/C v76
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Debug log:
Debug log started at Fri Sep 08 06:52:47 2023 , written by MakeMKV v1.17.4 win(x64-release)
001005:0000 MakeMKV v1.17.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\mitch/MakeMKV_log.txt
DEBUG: Code 3 at w.G,[.W,J~s[OWwzq<.Q$D1P:29395310
SDF  v098: PIONEER_BD-RW__BDR-XS07U_1.02_BLDL007676UC
001011:0000 Using LibreDrive mode (v01.0 id=CA5C627C459A)
001003:0020 DEBUG: Code 100864261 at Hu0Y6$"G%/26#v|y:121271617
001003:0020 DEBUG: Code 100864261 at spDZ-<~\bXU:/9Ia:213130559
001003:0020 DEBUG: Code 100864261 at XLZy#@p!6m/^{4B`f):121263429
001003:0020 DEBUG: Code 100864261 at XLZy#@p!6m/^{4B`f):121262302
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW  BDR-XS07U 1.02 BLDL007676UC' at offset '33370144768'
001003:0020 DEBUG: Code 100864261 at XLZy#@p!6m/^{4B`f):213132445
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW  BDR-XS07U 1.02 BLDL007676UC' at offset '33370204160'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW  BDR-XS07U 1.02 BLDL007676UC' at offset '33370275840'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW  BDR-XS07U 1.02 BLDL007676UC' at offset '33366736896'
001003:0020 DEBUG: Code 0 at {ENo'O@)<]A/Qfm:121262509
001003:0020 DEBUG: Code 0 at {ENo'O@)<]A/Qfm:213129846
001003:0020 DEBUG: Code 1 at {ENo'O@)<]A/Qfm:29395264
005084:0000 Failed to load content hash table, unable to verify integrity of M2TS files.
DEBUG: Code 2147483648 at Nx*e^{R_\6h/]Oy7:121265499
003344:0000 Using Java runtime from C:/Program Files (x86)/Java/jre-1.8/bin/javaw.exe
DISCID=4F562416515124D42E2C3BB7EA02B8219C358FC2
003025:0000 Title #00000.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00009.mpls was added as title #0
003025:0000 Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00049.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00075.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00093.mpls was added as title #1
003025:0000 Title #00153.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00806.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00001.mpls was added as title #2
003309:0000 Title 00090.mpls is equal to title 00001.mpls and was skipped
003309:0000 Title 00091.mpls is equal to title 00001.mpls and was skipped
003025:0000 Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00068.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00074.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Application exited at Fri Sep 08 06:58:25 2023
The drive is externally powered, cleaned the disc, tried a backup (same error), and Java is installed.
Any assistance appreciated.
Re: Can't rip 4K Edge of Tomorrow
#2 Post by MartyMcNuts » Fri Sep 08, 2023 10:36 pm
Mitchco wrote: Fri Sep 08, 2023 7:09 pm Hello, new to this, so maybe someone can spot the issue. Drive I am using:
Revision: 1.02
Disc Information
Number of layers: 3
Debug log:
Try a different USB 3 port or USB-C. Clean the disc again. Try doing a full disc to folder backup.
Mitchco
#3 Post by Mitchco » Sat Sep 09, 2023 4:49 pm
Thanks! Cleaned the disc again. I tried another USB port and then on a different computer, but same error and same location. I also tried on a Mac, same errors but seems different offsets... But an AACS file dump was produced on the Mac version and can be downloaded here: https://accuratesound.blob.core.windows ... w_37D3.tgz
When the error occurred, I pressed stop and got a screen shot with some additional information:
It seems I can't add an attachment yet, so the error says:
Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive.
Don't know if that is a real error or a result of stopping the process...
I ripped the 4K version of JAWS right after this attempt and was successful.
PS. Tried to do a back up, failed and tried to copy the files from the disc to hard drive and also failed.
Possible the disc is faulty?
