Asking for some help: New to Dolby Vision rips
moogerfoogers
Post by moogerfoogers »
Hey y'all. I recently bought a TCL Q7 65" Google TV. For or the first time I'm able to watch DV content. I'm having trouble watching ripped movies in DV. They seem to all fall back to HDR10. I know DV can be a very complicated subject. But I was wondering if someone could help me out a bit.
MY SETUP
TCL Q7, external SSD plugged into USB 3 port
MEDIA PLAYER APP
Any recommendations? The standard pre installed media player app worked playing a DV sample mp4 I've linked below.
VIDEO THAT WORKS
The only DV video I've been able to play via my SSD connected directly to the tv is a demo clip. Here is a link to the file - https://drive.google.com/file/d/14QIknF ... sp=sharing
Mediainfo:
Format : HEVC
Format profile : Main 10@L5.1@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.09, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Duration : 56 s 200 ms
Bit rate : 27.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.056
Stream size : 186 MiB (98%)
Encoded date : 2017-04-13 20:09:18 UTC
Tagged date : 2017-04-13 20:09:18 UTC
Codec configuration box : hvcC+dvcC
VIDEOS THAT DON'T WORK
All are in MKV format. Here are 2 examples of the video track details via Mediainfo
Format : HEVC
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 3 h 12 min
Bit rate : 24.7 Mb/s
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.124
Stream size : 33.2 GiB (95%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 287 cd/m2
Maximum Frame-Average Light Level : 201 cd/m2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Duration : 3 h 1 min
Bit rate : 16.5 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.083
Stream size : 20.9 GiB (96%)
Default : Yes
Forced : No
Color range : Full
I'm interested in learning how I can convert, mux (or whatever) I need to do in order to get these MKV files to play in DV instead of falling back to HDR10 on my TCL Q7. Do I need to convert them to MP4 like the example clip that worked on my TV? I appreciate anyone's time/help in pointing me in the right direction.
PS/ I tried converting the MKV files to MP4 in FFMPEG, but that unfortunately didn't work.
demon
Re: Asking for some help: New to Dolby Vision rips
Post by demon »
Sounds like it only likes certain versions of the Dolby Vision metadata format. I think you'd need to use dovi_tool to convert it, but I'm not sure of the specifics. Apparently it only like the 05.09 version?
Ezatoka
Post by Ezatoka »
Not sure if I found the correct one, but https://www.tcl.com/us/en/products/home ... tv-65q750g states:
High Dynamic Range Format
HDR PRO+, Dolby Vision, HDR10+, HDR10, HLG
So not very specific about versions there
