That's the thing. I processed an MKV earlier, netting me the same error. So I figured an HEVC would be succeed:RESET_9999 wrote: ↑Thu Sep 07, 2023 3:41 pmraw hevc h265 input not supported in 3-1.
-- Input must be HDR MKV/TS/M2TS/MP4/prores for the video and the external files: MDL5-bat/xml/rpu/json/txt
Version: 1.9.2.9.beta_MKV Date: 05-09-2023 05:02
Contact: R3S3T_9999@proton.me
_____ __ ___ _____ _ _
| __ \ \ \ / (_) / ____| (_) | |
| | | | __\ \ / / _ | (___ ___ _ __ _ _ __ | |_ ___
| | | |/ _ \ \/ / | | \___ \ / __| '__| | '_ \| __/ __|
| |__| | (_) \ / | | ____) | (__| | | | |_) | |_\__ \
|_____/ \___/ \/ |_| |_____/ \___|_| |_| .__/ \__|___/
-Author: RESET_9999--------------------------|__|-----------
Choose a mode...
1) MODE.I= DoVi Inject/Convert/Edit/Re-sync TWO INPUTS (P8 Hybrid maker/Injector)
2) MODE.F= DoVi Fix/Edit/Extract/Verify/Info ONE INPUT
3) MODE.H= DoVi Maker from HDR10 (Dolby Algo or madVR or HDR10plus)
4) MODE.7= DoVi Profile 7 Input (MKV/BDMV)
5) MODE.B= DoVi MKV Batch Muxer
6) MODE.P= DoVi Plotter
7) MODE.S= DoVi Screenshots maker
8) MODE.M= MIXED: Audio/Remover/Player/Encoder and more...
9) Exit
Choice? [1,2,3,4,5,6,7,8,9]?3
* CHOOSE A MODE *
1) MODE.1= CM_analyzer HDR10 to DoVi maker(can batch) (Professional CM v4.0 Dolby Algo)
2) MODE.2= HDR10(madVR) or HDR10plus to DoVi maker (Not Recommended)
3) MODE.3= BATCH convert HDR10plus videos to DoVi (Not Recommended)
4) MODE.4= Batch measure a folder with mkv HDR10 files
5) MODE.5= Back to main menu
Choice? [1,2,3,4,5]?1
-- This workflow will convert an HDR10 video to DoVi using official Dolby Vision tools
-- Require Dolby metafier.exe and cm_analyze.exe
-- https://customer.dolby.com/content-creation-and-delivery/dolby-vision-professional-tools
-- L1 analysis tuning can be configured at line 100
-- if no external shot and If input has dynamic metadata, it will use its scene cuts.
-- If input has no dynamic metadata and no external list, madvr will be used for the shot list
-- You can force frame by frame(line 103)
-- if you dont provide external config.bat, the same L5/MDL will be used
-- External files: must be same path/filename as input. (bat/xml/rpu/json/txt) external files are prioritized.
-- External files will be moved into the output_path, do not move nor delete them until the script has completed
Drag and drop folder with HEVC video files ONLY and press enter...
"E:\The Grand Tour\Series 5\S05E01 - A Scandi Flick (missing chapters) (2160p Dual Video HDR10+ and Dolby Vision Amazon Prime Web-DL).mkv"
A subdirectory or file E:\Movie_Tools\DoVi_Scripts\Files_for_batch\ already exists.
BL Mastering Display Luminance and Colors:
min: 0.0001 cd/m2, max: 1000 cd/m2 Display P3
What is the Mastering Display? Choices are: 1000nits-P3= 20(default) / 1000nits-BT2020= 21 / 4000nits-P3= 7 / 4000nits-BT2020= 8 / 2000nits-P3= 30 / 2000nits-BT2020= 31
7
Manual or Auto L5... a or m ? and/or press enter... (default=m)
m
Making a small sample from the input...
Done
Measuring the letterbox...
Done
Suggestion (may not be accurate):
--> left border: 0
--> right border: 0
--> top border: 0
--> bottom border: 0
Left L5 offset (default = 0)
Right L5 offset (default = 0)
Top L5 offset (default = 0)
Bottom L5 offset (default = 0)
Processing... "E:\The Grand Tour\Series 5\S05E01 - A Scandi Flick (missing chapters) (2160p Dual Video HDR10+ and Dolby Vision Amazon Prime Web-DL).mkv"
reading input tracks format/id/language...
done.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\BL.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Reordering metadata... Done.
Reading parsed dynamic metadata... Done.
Generating and writing metadata to JSON file... Done.
Parsing RPU file...
Exporting metadata...
Done.
Exporting shots list from a HDR10plus JSON to a text file...
Parsing RPU file...
Done.
Indexing, please wait... 100%
Writing index... done.
E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\script.avs: Unknown error occurred
Copyright (c) 2013-2023 Dolby Laboratories, Inc. All Rights Reserved
09/07/2023/16:06:33.125000000 CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz (GenuineIntel) [ mmx sse sse2 sse3 ssse3 sse41 sse42 avx avx2 ]
09/07/2023/16:06:33.250000000 cm_analyze: ERROR Unable Open Sequence 'E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\S05E01 - A Scandi Flick (missing chapters) (2160p Dual Video HDR10+ and Dolby Vision Amazon Prime Web-DL)_prores.422.mov'. Check file permissions are/or existence
Removing L2 trims.
09/07/2023/16:06:35.482000000 metafier: ERROR Unable to open Metadata file 'E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\S05E01 - A Scandi Flick (missing chapters) (2160p Dual Video HDR10+ and Dolby Vision Amazon Prime Web-DL)_DV.xml'
Generate RPU from XML
Parsing XML metadata...
Error: The system cannot find the file specified. (os error 2)
