spiderman into the spider verse
treytcg
Post by treytcg » Thu Sep 07, 2023 10:30 pm
a brand new disk, brand new drive.. wouldn't copy. can you fix, please?
Saving 6 titles into directory F:/Media/ripped media/Movies
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32893501440'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32893562880'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32893894656'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32893956096'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '32893956096'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32894349312'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32894613504'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32894810112'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '32894810112'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32894877696'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '32894877696'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32894939136'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32895006720'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '32895006720'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32895006720'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32895074304'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32895467520'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '32895467520'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32895725568'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '32895725568'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '32895725568'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32895725568'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32895725568'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '32895725568'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '32895725568'
Failed to save title 0 to file F:/Media/ripped media/Movies/Spider-Man- Across The Spider-Verse-FPL_MainFeature_t00.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00102.m2ts' at offset '0'
Failed to save title 1 to file F:/Media/ripped media/Movies/Spider-Man- Across The Spider-Verse-Test Patterns_t01.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00722.m2ts' at offset '0'
Failed to save title 2 to file F:/Media/ripped media/Movies/Spider-Man- Across The Spider-Verse-SF_ForcedTrailers_1_t02.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00723.m2ts' at offset '0'
Failed to save title 3 to file F:/Media/ripped media/Movies/Spider-Man- Across The Spider-Verse-SF_ForcedTrailers_2_t03.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00099.m2ts' at offset '0'
Failed to save title 4 to file F:/Media/ripped media/Movies/Spider-Man- Across The Spider-Verse-TMPL Main Menu_t04.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '0'
Failed to save title 5 to file F:/Media/ripped media/Movies/Spider-Man- Across The Spider-Verse_t05.mkv
Encountered 40 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 6 failed
Re: spiderman into the spider verse
Post by Woodstock » Fri Sep 08, 2023 1:07 am
Errors look like the drive doesn't have enough power to run at full speed. Is this a USB-powered device, and are you using a single or dual cable with it?
