Post by RESET_9999 » Wed Sep 06, 2023 5:45 pm
Trees wrote: Wed Sep 06, 2023 5:01 pm Why isn't converting HDR10+ to Dolby Vision not recommended? Is this because the Dolby Algorithm is just better or are there other reasons?
The main reason is the average pq metadata, Dolby Vision is very different.
HDR10plus and madvr generation have very dynamic avg_pq numbers compared to DV which can cause some brightness fluctuation between shots.
https://slow.pics/c/WlGwchoE
sw5163
Post by sw5163 » Thu Sep 07, 2023 3:09 am
EncodeThis420 wrote: Thu Aug 03, 2023 8:43 pm
bobbymkV wrote: Thu Aug 03, 2023 8:05 pm
EncodeThis420 wrote: Thu Aug 03, 2023 5:08 pm
Thanks. This is kind of what I was afraid of. There's really no way (for a normal person like myself) to tell whether a "hybrid" encode was done properly. I'm basically seeing ONLY hybrid files for all new streaming shows being encoded. These encoders are not posting the original profile 5 sources which is absolutely infuriating. I rather just grab P5 versions so that I know that it has the correct brightness. Why in the world are people not doing this? What changed? Is there any possible way to like "reverse engineer" these files to split back out the p5 stream? or is that impossible?
I stopped grabbing p8 hybrids earlier this year when I learned all of this. There is really only one uploader that I trust.
Is there any way that you could share which uploader you trust? Not sure of the rules here or if you can even send private messages. Feel free to decline if I am crossing a line.
But yea. I just don't understand it.....uploaders who used to upload source P5 materials just randomly all switched to uploading P8 files. I have no idea what happened. I legit cannot find any P5 files of recent streamed shows. They're literally all P8 lol. If they know that P8 files are bad form....then why do they keep doing it?
Most dv release groups I know stop releasing P5. There's a Chinese group still releases itunes P5, but I don't know if they were the original uploader or they just modified someone else. And I'm also looking for more trusted release group, their releases sometimes just broke, frame rate slightly off, etc.
Indiana.Jones.and.the.Dial.of.Destiny.2023.2160p.iTunes.WEB-DL.DDP.7.1.Atmos.DV.H.265-DreamHD
I really hope groups could upload P5 and P8.1 separately, instead of just hybrid them. I think with the increase of brightness in screen panel, brightness mapping in RPU is becoming less important. The 11.5 bit color of P5 and 4:2:2 sampling of P7 seems more beneficial.
thirdmoon
Post by thirdmoon » Thu Sep 07, 2023 7:15 am
@RESET_9999
1. What is the best alternative for watching FEL content on non FEL supported devices.
2. Is it possible to generate HDR10+ plus data using official scene cuts.
Thank you.
Post by RESET_9999 » Thu Sep 07, 2023 11:04 am
thirdmoon wrote: Thu Sep 07, 2023 7:15 am @RESET_9999
Thank you.
1. dovi baker + x265 with decent encode settings ( at least CRF-17 slow preset)
2- no
NiCE77
Post by NiCE77 » Thu Sep 07, 2023 11:48 am
@RESET_9999
I'm trying the DoViBaker workflow, is it normal that with Ryzen 7 7840HS + RTX 4060 the conversion speed is about 2.4 fps (0.1x) only?
Post by RESET_9999 » Thu Sep 07, 2023 12:09 pm
NiCE77 wrote: Thu Sep 07, 2023 11:48 am @RESET_9999
I don't know.
With my i9 13900ks + rtx3070, it's slightly slower than a regular HDR encode, about 6-7fps at slow preset.
NiCE77
Post by NiCE77 » Thu Sep 07, 2023 12:14 pm
RESET_9999 wrote: Thu Sep 07, 2023 12:09 pm
I don't know.
Thanks, then it's normal :(
skull88
Post by skull88 » Thu Sep 07, 2023 12:18 pm
NiCE77 wrote: Thu Sep 07, 2023 12:14 pm
I don't know.
Alternatively, you can always buy a good UHD BD player and your favourite (FEL) movies on disc. Time is money, no? :wink:
Trees
Post by Trees » Thu Sep 07, 2023 3:27 pm
RESET_9999 wrote: Wed Sep 06, 2023 5:45 pm
Thanks for the information.
I'm trying to create a CM 4.0 DV video from an HDR10+ video. However, I'm getting some errors. Any ideas? Here is the terminal output:
Version: 1.9.2.9.beta_MKV        Date: 05-09-2023 05:02
   Contact: R3S3T_9999@proton.me
                        _____    __      ___       _____           _       _
                       |  __ \   \ \    / (_)     / ____|         (_)     | |
                       | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
                       | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
                       | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
                       |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
                       -Author: RESET_9999--------------------------|__|-----------
 Choose a mode...
1) MODE.I=  DoVi Inject/Convert/Edit/Re-sync TWO INPUTS (P8 Hybrid maker/Injector)
2) MODE.F=  DoVi Fix/Edit/Extract/Verify/Info ONE INPUT
3) MODE.H=  DoVi Maker from HDR10 (Dolby Algo or madVR or HDR10plus)
4) MODE.7=  DoVi Profile 7 Input (MKV/BDMV)
5) MODE.B=  DoVi MKV Batch Muxer
6) MODE.P=  DoVi Plotter
7) MODE.S=  DoVi Screenshots maker
8) MODE.M=  MIXED: Audio/Remover/Player/Encoder and more...
9) Exit
Choice? [1,2,3,4,5,6,7,8,9]?3
                                           * CHOOSE A MODE *
1) MODE.1= CM_analyzer HDR10 to DoVi maker(can batch) (Professional CM v4.0 Dolby Algo)
2) MODE.2= HDR10(madVR) or HDR10plus to DoVi maker (Not Recommended)
3) MODE.3= BATCH convert HDR10plus videos to DoVi (Not Recommended)
4) MODE.4= Batch measure a folder with mkv HDR10 files
5) MODE.5= Back to main menu
Choice? [1,2,3,4,5]?1
-- Input must be HDR MKV/TS/M2TS/MP4/prores for the video and the external files: MDL5-bat/xml/rpu/json/txt
-- This workflow will convert an HDR10 video to DoVi using official Dolby Vision tools
-- Require Dolby metafier.exe and cm_analyze.exe
-- https://customer.dolby.com/content-creation-and-delivery/dolby-vision-professional-tools
-- L1 analysis tuning can be configured at line 100
-- if no external shot and If input has dynamic metadata, it will use its scene cuts.
-- If input has no dynamic metadata and no external list, madvr will be used for the shot list
-- You can force frame by frame(line 103)
-- if you dont provide external config.bat, the same L5/MDL will be used
-- External files: must be same path/filename as input. (bat/xml/rpu/json/txt) external files are prioritized.
-- External files will be moved into the output_path, do not move nor delete them until the script has completed
Drag and drop folder with HEVC video files ONLY and press enter...
"E:\Movie_Tools\DoVi_Scripts\S05E01 - A Scandi Flick (HDR10+).hevc"
A subdirectory or file E:\Movie_Tools\DoVi_Scripts\Files_for_batch\ already exists.
 BL Mastering Display Luminance and Colors:
 min: 0.0001 cd/m2, max: 1000 cd/m2 Display P3
What is the Mastering Display? Choices are: 1000nits-P3= 20(default) / 1000nits-BT2020= 21 / 4000nits-P3= 7 / 4000nits-BT2020= 8 / 2000nits-P3= 30 / 2000nits-BT2020= 31
7
Manual or Auto L5... a or m ? and/or press enter... (default=m)
a
Processing... "E:\Movie_Tools\DoVi_Scripts\S05E01 - A Scandi Flick (HDR10+).hevc"
reading input tracks format/id/language...
done.
Making a small sample from the input...
Done!
Measuring the letterbox...
Done!
--> left border: 0
--> right border: 0
--> top border: 0
--> bottom border: 0
tsMuxeR version git-de67de8. github.com/justdan96/tsMuxer
HEVC muxing fps is not set. Get fps from stream. Value: 25
B-pyramid level 1 detected. Shift DTS to 2 frames
99.9% complete
Processed 149707 video frames
100.0% complete
Flushing write buffer
Demux complete.
Demuxing time: 7 min 28 sec
Reordering metadata... Done.
Reading parsed dynamic metadata... Done.
Generating and writing metadata to JSON file... Done.
Parsing RPU file...
Exporting metadata...
Done.
Exporting shots list from a HDR10plus JSON to a text file...
Parsing RPU file...
Done.
Indexing, please wait... 100%
Writing index... done.
E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\script.avs: Unknown error occurred
Copyright (c) 2013-2023 Dolby Laboratories, Inc. All Rights Reserved
09/07/2023/17:15:14.921000000 CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz (GenuineIntel) [ mmx sse sse2 sse3 ssse3 sse41 sse42 avx avx2 ]
09/07/2023/17:15:14.938000000 cm_analyze: ERROR Unable Open Sequence 'E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\S05E01 - A Scandi Flick (HDR10+)_prores.422.mov'. Check file permissions are/or existence
Removing L2 trims.
09/07/2023/17:15:15.952000000 metafier: ERROR Unable to open Metadata file 'E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\S05E01 - A Scandi Flick (HDR10+)_DV.xml'
Generate RPU from XML
Parsing XML metadata...
Error: The system cannot find the file specified. (os error 2)
Post by RESET_9999 » Thu Sep 07, 2023 3:41 pm
Trees wrote: Thu Sep 07, 2023 3:27 pm I'm trying to create a CM 4.0 DV video from an HDR10+ video. However, I'm getting some errors. Any ideas? Here is the terminal output:
raw hevc h265 input not supported in 3-1.
Trees
Post by Trees » Thu Sep 07, 2023 4:36 pm
RESET_9999 wrote: Thu Sep 07, 2023 3:41 pm
That's the thing. I processed an MKV earlier, netting me the same error. So I figured an HEVC would be succeed:
 Choose a mode...
9) Exit
                                           * CHOOSE A MODE *
"E:\The Grand Tour\Series 5\S05E01 - A Scandi Flick (missing chapters) (2160p Dual Video HDR10+ and Dolby Vision Amazon Prime Web-DL).mkv"
7
m
Done
Done
Suggestion (may not be accurate):
--> left border: 0
--> right border: 0
--> top border: 0
Left L5 offset (default = 0)
Right L5 offset (default = 0)
Top L5 offset (default = 0)
Bottom L5 offset (default = 0)
Processing... "E:\The Grand Tour\Series 5\S05E01 - A Scandi Flick (missing chapters) (2160p Dual Video HDR10+ and Dolby Vision Amazon Prime Web-DL).mkv"
done.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\BL.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Parsing RPU file...
Done.
Parsing RPU file...
Done.
09/07/2023/16:06:33.125000000 CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz (GenuineIntel) [ mmx sse sse2 sse3 ssse3 sse41 sse42 avx avx2 ]
09/07/2023/16:06:33.250000000 cm_analyze: ERROR Unable Open Sequence 'E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\S05E01 - A Scandi Flick (missing chapters) (2160p Dual Video HDR10+ and Dolby Vision Amazon Prime Web-DL)_prores.422.mov'. Check file permissions are/or existence
Removing L2 trims.
09/07/2023/16:06:35.482000000 metafier: ERROR Unable to open Metadata file 'E:\Movie_Tools\DoVi_Scripts\TEMP.folder77\S05E01 - A Scandi Flick (missing chapters) (2160p Dual Video HDR10+ and Dolby Vision Amazon Prime Web-DL)_DV.xml'
Post by RESET_9999 » Thu Sep 07, 2023 4:43 pm
Trees wrote: Thu Sep 07, 2023 4:36 pm That's the thing. I processed an MKV earlier, netting me the same error. So I figured an HEVC would be succeed:
Oh yeah, I forgot to mention that input with '')'' in the filename will not work so just rename your file.
bivoj
Post by bivoj » Thu Sep 07, 2023 5:05 pm
Hello, when using mod 3-1, I get a different 422.prores.mov in 1.9.2.9 than in the 1.9.2.6, according to mediainfo.
In CM_analysis the completion times are:
1.9.2.6 - 00:04:14
1.9.2.9 - 00:17:30
Below are pictures with the differences. Thank you for the explanation.
mode 3-1
script 1.9.2.6
mode 3-1
script 1.9.2.9
mode 3-1
script 1.9.2.6
mode 3-1
script 1.9.2.9
My english is very bad, forgive me for that. :-)
Trees
Post by Trees » Thu Sep 07, 2023 5:52 pm
RESET_9999 wrote: Thu Sep 07, 2023 4:43 pm
Same error. I even removed all special characters. Also the + and the -. Seems like there is an issue with:
Or not?
Post by RESET_9999 » Thu Sep 07, 2023 6:03 pm
Trees wrote: Thu Sep 07, 2023 5:52 pm Same error. I even removed all special characters. Also the + and the -. Seems like there is an issue with:
Or not?
I don't know. I cannot reproduce it even with the same exact name/folder you used minus '')''
So maybe your file has an issue?
EDIT: I added an option to disable indexing (line 132)... while I don't recommend disabling it, it should fix the issue with your file.
https://drive.google.com/file/d/1f34d80 ... sp=sharing
