i get this really long error code and says something about no key to open the disc.
my bluray reader is an external drive. i'll test other blurays in the meantime
Update
i've tried to open 3 different blurays, one of which i've used before to rip successfully...and now it wont.
Error on BD Evangelion You Can Not Advance anime movie
Re: Error on BD Evangelion You Can Not Advance anime movie
I see that you have seen the thread about AACS bus encryption.Drive 'HL-DT-ST BD-RE UH12LS28 1.00' requires AACS bus encryption, disc decryption may fail.
Did you rip the previous discs with this drive, or another drive?
SC
i just had this drive replaced with a new one, the previous same model was not burning lightscribe discs so i was sent a new one....and now of course because its a new external, i can't rip, so yea i understand now. i just hope makemkv update is soon
I don't know what your talking about. Im currently using version. 1.6.10 and I get the error still. Besides the mod said we will get this error with later model drives.
Woodstock wrote:FWIW, if the BD drive is working, Evangelion 2.22 extracts just fine with MakeMKV 1.6.8 and 1.6.10.
You currently can't use the drive that you have. What I believe Woodstock is saying, is that it would work if your drive wasn't constrained by the AACS bus encryption.
SC
edit - Thanks Romansh!
SC
That's what I thought but useless.
You mean he can't, right?Smithcraft wrote:You currently can use the drive that you have.
