Bruce Almighty seeking problems
traxxus
Post by traxxus »
Hi peoples
I have successfully copied Bruce Almighty Bluray with makemkv. No errors, nothing bad.
But the playback is very bugged. In MPC-HD or WMP or XBMC, alls the same bug:
The seeking doesn't work.
MPC-HD is buffering for ever, WMP crashes and XBMC doesn't show the timeline correct. But the playback from beginning without seeking works flawless.
i tried makemkv with/without anydvd. Same thing.
Playback directly from disc - NO problems.
OS: Wind 7 x64
Drive: LG Bluray drive
MakeMKV: 1.6.10
Ideas?
crowfax
Re: Bruce Almighty seeking problems
Post by crowfax »
You're not the only one with issues. Here's my long thread about it:
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=3634
Mike is working on it, all we can do is wait. For now you can roll back to 1.6.8 and the generated MKV files will work.
