Integration with ripping robot
BluDay
#1 Post by BluDay » Fri Sep 01, 2023 2:46 pm
I have a ripping robot (Cronus from Vinpower) - has anyone successfully managed to integrate a robot into makemkv?
Ideally I would get it to automatically rip DVDs/BluRays into .mkv.
Re: Integration with ripping robot
#2 Post by Woodstock » Fri Sep 01, 2023 5:48 pm
One consideration will be that a lot of DVDs and some Blurays have "no identification", so you'll have to deal with automatic tools assigning them generic names. If that's not a problem, things get easier.
flojo
#3 Post by flojo » Sun Sep 03, 2023 12:16 am
First, I seriously doubt you'll be able to install makemkvcon on the internal system. But of course find out what the internal operating system is first, just in case.
Your autoloader states here https://www.vinpowerdigital.com/product ... -bk-series:
Command line support:
Able to integrate customer's own software to operate loader – allows customized API software support
Sadly, I don't see any API documentation on their support page for controlling it. If you can find that, then you could *possibly* do it by issuing a "change disc" command then after the disc changes, disconnect the UHD drive and connect it to your PC. After ripping, reconnect back to the autoloader. You might need to reboot the loader too as I seriously doubt it's setup for hot plugging (although that would be nice).
I've seen all this done with Padus DiscJuggler based systems a long, long, long time ago. However, the 1 advantage you have is that you can issue a "change disc" command via software. Otherwise it takes a little hardware hacking with cheap optoresistors and a little soldering (or strong solenoids to push buttons). The advantage of using a few hardware hacks is that it can work no matter what... at least with enough software.
NOTE: you don't need a fancy API for this, you pretty much just need a change disc command, a drive choice and a bin choice to drop the disc. So if you see a huge API list, just know you really only need a few commands (most will be irrelevant for this, like JITTER=, PRINT=, etc.)
