Re: Pioneer firmware update February 2023
arremelle wrote: Mon Aug 14, 2023 1:36 pm Hi,
I have the same drive and situation as Asian wolf. I just got my drive from Amazon yesterday and I can read blu-rays just fine but not UHD.
MakeMKV is connected to the internet and I have been using it also for many years with DVD/Blu-rays no problem.
Replying so I can see any updates. Thanks in advanced for the support.
Best thing to do is return it and buy a preflashed one from a seller in your region
MrEJ42
Post by MrEJ42 »
Billycar11 wrote: Mon Aug 14, 2023 3:35 pm
I wish that was an option for me, but I bought my drive back in May based on the recommendation from another site. I didn't find out about this site until I eventually got around to trying it out this month.
neglectedpets
Post by neglectedpets »
I had to send my BDR-XS07UHD in for service as the drive stopped functioning after only 8 months. I hadn't heard about the new Pioneer firmware issue until the last few days. I just got the drive back today and it has the dreaded 1.03 firmware so I'm dead in the water now I guess. Pretty bummed. I hope there's a solution soon, otherwise I'll be buying a new drive.
MrEJ42
Post by MrEJ42 »
neglectedpets wrote: Thu Aug 31, 2023 10:50 pm I had to send my BDR-XS07UHD in for service as the drive stopped functioning after only 8 months. I hadn't heard about the new Pioneer firmware issue until the last few days. I just got the drive back today and it has the dreaded 1.03 firmware so I'm dead in the water now I guess. Pretty bummed. I hope there's a solution soon, otherwise I'll be buying a new drive.
It worries me that they haven't found a solution by now.
I_Like_Turtles_Doode
Post by I_Like_Turtles_Doode »
MrEJ42 wrote: Fri Sep 01, 2023 3:06 am
It's been pretty quiet from them about this.
I_Like_Turtles_Doode wrote: Fri Sep 01, 2023 2:10 pm
...which usually means it's being worked hard on it.
Krawk
Post by Krawk »
I had bought a second BDR-S13UBK and it came with a newer firmware. Strongly considering returning it unless we know reasonably sure there will be a fix in the future. It is unopened and unused to I am not screwing over the merchant.
randomuser001
Post by randomuser001 »
Yeah I'm in the same boat Krawk. I bought a new Pioneer blu ray drive. I don't want to screw over the merchant and return it since it's honestly perfectly good. I would love to know if they had a rough estimate on if they will be able to get a fix and if so around when.
Krawk wrote: Wed Sep 06, 2023 9:10 pm I had bought a second BDR-S13UBK and it came with a newer firmware. Strongly considering returning it unless we know reasonably sure there will be a fix in the future. It is unopened and unused to I am not screwing over the merchant.
Good choice for now.
palindromico
Post by palindromico »
Hello everyone.
I own a Pioneer BDR-XS07UHD which had the FW suitable for acquiring UHD BRDs but which I, very intelligently, updated to the latest version... (I wasn't aware of the problem, I discovered it a few days ago)
I retrieved the link to the FWs prior to 1.03 from the Pioneer website, and downloaded them, but I wonder: is it that simple to downgrade the FW? Maybe I'm paranoid but... has anyone tried?
I don't want to make the player completely unusable, since I'm also backing up my non-UHD BRDs...
Thanks in advance!!!
Marco
You are out of luck until there is a solution.
palindromico
Yes... I imagined: therefore (as I feared) it is impossible to downgrade the FW...
I really was an idiot... My fault.
TeddyRaspin
Post by TeddyRaspin »
It is possible, you only have to wait patiently.
mickstaa
Post by mickstaa »
Hello all,
Noob here. can someone point me in the direction to patched UHD enabling firmware for my drive:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.00
Serial number: SGDL000006WL
Firmware date: 2019-01-10
Highest AACS version: 19
Drive platform: RS8F01
Firmware version: 1.00/ID43
mickstaa wrote: Tue Sep 12, 2023 10:40 am Hello all,
OS device name: F:
Revision: 1.00
you are good as is do not update it leave it. if its not working you have a different issue like your hk not downloading
