V1.8.9 & The Frighteners (15Th Anniversary Edition)
millifoo
Post by millifoo »
I did a search for "Frighteners" but didn't see any existing threads.
Initial load up log first, then rip fails below, delineated by "-----------"
MakeMKV v1.8.9 darwin(x86-release) started
Optical drive "BD-ROM HL-DT-ST BDDVDRW CT30N WS03" opened in DASPI v1.4 mode.
Title #00013.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50311.m2ts' at offset '0'
Title #00315.mpls was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50312.m2ts' at offset '0'
Title #00322.mpls was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50313.m2ts' at offset '0'
Title #00302.mpls was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50314.m2ts' at offset '0'
Title #00306.mpls was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50315.m2ts' at offset '0'
Title #00332.mpls was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50199.m2ts' at offset '0'
Title #00020.mpls was skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
Title #00303.mpls was skipped
Title #00307.mpls was skipped
Title #00308.mpls was skipped
Title #00309.mpls was skipped
Title #00310.mpls was skipped
Title #00311.mpls was skipped
Title #00312.mpls was skipped
Title #00313.mpls was skipped
Title #00316.mpls was skipped
Title #00317.mpls was skipped
Title #00318.mpls was skipped
Title #00319.mpls was skipped
Title #00320.mpls was skipped
Title #00323.mpls was skipped
Title #00324.mpls was skipped
Title #00325.mpls was skipped
Title #00326.mpls was skipped
Title #00327.mpls was skipped
Title #00328.mpls was skipped
Title #00329.mpls was skipped
Title #00330.mpls was skipped
Title #00333.mpls was skipped
Title #00334.mpls was skipped
Title #00335.mpls was skipped
Title #00339.mpls was skipped
Title #00339.mpls(1) was skipped
Title #00339.mpls(2) was skipped
Title #00339.mpls(3) was skipped
Title #00339.mpls(4) was skipped
Title #50057.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50058.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50199.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50200.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 50201.m2ts was added as title #2
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50202.m2ts' at offset '0'
Title #50202.m2ts was skipped
Title #50278.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50283.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 50284.m2ts was added as title #3
File 50285.m2ts was added as title #4
File 50286.m2ts was added as title #5
File 50287.m2ts was added as title #6
File 50288.m2ts was added as title #7
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50289.m2ts' at offset '0'
Title #50289.m2ts was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50290.m2ts' at offset '0'
Title #50290.m2ts was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '0'
Title #50291.m2ts was skipped
Title #50292.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50293.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50294.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50295.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 50296.m2ts was added as title #8
Title #50297.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 50298.m2ts was added as title #9
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50299.m2ts' at offset '0'
Title #50299.m2ts was skipped
File 50300.m2ts was added as title #10
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50301.m2ts' at offset '0'
Title #50301.m2ts was skipped
File 50302.m2ts was added as title #11
File 50303.m2ts was added as title #12
Title #50304.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50305.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 50306.m2ts was added as title #13
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50307.m2ts' at offset '0'
Title #50307.m2ts was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50308.m2ts' at offset '0'
Title #50308.m2ts was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50309.m2ts' at offset '0'
Title #50309.m2ts was skipped
Title #50310.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50311.m2ts was skipped
Title #50312.m2ts was skipped
Title #50313.m2ts was skipped
Title #50314.m2ts was skipped
Title #50315.m2ts was skipped
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50316.m2ts' at offset '0'
Title #50316.m2ts was skipped
Title #50317.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title information
Name: The Frighteners
Source file name: 00800.mpls
Duration: 1:49:52
Chapters count: 16
Segment count: 18
Segment map: 50201,50292,50284,50298,50287,50297,50286,50296,50285,50295,50288,50299,50289,50301,50290,50293,50291,50294
File name: The_Frighteners_t00.mkv
Saving 1 titles into directory /Users/<username>/Movies/The_Frighteners
Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/50294.m2ts' at offset '0'
Failed to save title 0 to file /Users/<username>/Movies/The_Frighteners/The_Frighteners_t00.mkv
0 titles saved, 1 failed
Title information
Source file name: 00801.mpls
Duration: 2:02:36
Chapters count: 48
Segment count: 17
Segment map: 50201,50300,50284,50302,50287,50304,50286,50306,50285,50303,50288,50308,50289,50307,50290,50305,50291
File name: The_Frighteners_t01.mkv
Saving 1 titles into directory /Users/jeff/Movies/The_Frighteners
Failed to save title 1 to file /Users/<username>/Movies/The_Frighteners/The_Frighteners_t01.mkv
gfnmkv1972
Re: V1.8.9 & The Frighteners (15Th Anniversary Edition)
Post by gfnmkv1972 »
Did you ever figure out what the source of this problem was? I am getting similar errors while trying to read two brand new (2021/early 2022) BluRays (FWIW Black Widow and Shang-Chi).
Debug log started at Wed Jan 12 23:17:32 2022 , written by MakeMKV v1.16.5 darwin(x64-release)
001005:0000 MakeMKV v1.16.5 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/<username>/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.64.1/(SecureTransport) LibreSSL/2.8.3 (x86_64-apple-darwin19.0) , proxy server not set.
002010:0000 Optical drive "BD-ROM HL-DT-ST DVDRWBD CA30N A100 K0KAABM3431d" opened in OS access mode.
No  SDF v07f: HL-DT-ST_DVDRWBD_CA30N_A100_200907171620_K0KAABM3431
SDF id v07f: HL-DT-ST_DVDRWBD_CA30N_A100_200907171620_K0KAABM3431
No auto SDF v07f: HL-DT-ST_DVDRWBD_CA30N_A100_200907171620_K0KAABM3431
DEBUG: Code 0 at tAW//yQ,~P>EnV=9":121264142
DEBUG: Code 0 at _wXRS,@^*L(w1+@q:213136769
001003:0020 DEBUG: Code 100999424 at _wXRS,@^*L(w1+@q:29403291
001003:0020 DEBUG: Code 100999424 at [;8I:%i(<LqU|.bx:213130559
001003:0020 DEBUG: Code 100999424 at %"W67I`+,,'%Cb;iqN:29395195
001003:0020 DEBUG: Code 100999424 at %"W67I`+,,'%Cb;iqN:29393792
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/JAR/00000.jar' at offset '0'
001003:0020 DEBUG: Code 100999424 at %"W67I`+,,'%Cb;iqN:121263935
001003:0020 DEBUG: Code 0 at ,@rjb?.Q3Wm/=F!:213130030
001003:0020 DEBUG: Code 0 at q)3*^k0QW2*w%}_6:213121221
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/00932.m2ts' at offset '402604032'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:LOGICAL BLOCK ADDRESS OUT OF RANGE' occurred while reading '/BDMV/STREAM/00932.m2ts' at offset '1129979904'
gfnmkv1972 wrote: Sat Jan 15, 2022 2:31 am Did you ever figure out what the source of this problem was? I am getting similar errors while trying to read two brand new (2021/early 2022) BluRays (FWIW Black Widow and Shang-Chi).
What happens if you make a decrypted backup of the disc first then try to make the .mkv from that? That's my standard workflow and I've been successful with Black Widow.
gfnmkv1972
I have several files with similar problems (error codes). I attempted to follow your suggestion, but the decrypted backup failed. I am pretty stumped as to what to try next.
