Best thing to do is return it and buy a preflashed one from a seller in your regionarremelle wrote: Mon Aug 14, 2023 1:36 pm Hi,
I have the same drive and situation as Asian wolf. I just got my drive from Amazon yesterday and I can read blu-rays just fine but not UHD.
MakeMKV is connected to the internet and I have been using it also for many years with DVD/Blu-rays no problem.
Replying so I can see any updates. Thanks in advanced for the support.
Re: Pioneer firmware update February 2023
I wish that was an option for me, but I bought my drive back in May based on the recommendation from another site. I didn't find out about this site until I eventually got around to trying it out this month.Billycar11 wrote: Mon Aug 14, 2023 3:35 pmBest thing to do is return it and buy a preflashed one from a seller in your regionarremelle wrote: Mon Aug 14, 2023 1:36 pm Hi,
neglectedpets
I had to send my BDR-XS07UHD in for service as the drive stopped functioning after only 8 months. I hadn't heard about the new Pioneer firmware issue until the last few days. I just got the drive back today and it has the dreaded 1.03 firmware so I'm dead in the water now I guess. Pretty bummed. I hope there's a solution soon, otherwise I'll be buying a new drive.
It worries me that they haven't found a solution by now.neglectedpets wrote: Thu Aug 31, 2023 10:50 pm I had to send my BDR-XS07UHD in for service as the drive stopped functioning after only 8 months. I hadn't heard about the new Pioneer firmware issue until the last few days. I just got the drive back today and it has the dreaded 1.03 firmware so I'm dead in the water now I guess. Pretty bummed. I hope there's a solution soon, otherwise I'll be buying a new drive.
I_Like_Turtles_Doode
It's been pretty quiet from them about this.MrEJ42 wrote: Fri Sep 01, 2023 3:06 amIt worries me that they haven't found a solution by now.neglectedpets wrote: Thu Aug 31, 2023 10:50 pm I had to send my BDR-XS07UHD in for service as the drive stopped functioning after only 8 months. I hadn't heard about the new Pioneer firmware issue until the last few days. I just got the drive back today and it has the dreaded 1.03 firmware so I'm dead in the water now I guess. Pretty bummed. I hope there's a solution soon, otherwise I'll be buying a new drive.
...which usually means it's being worked hard on it.I_Like_Turtles_Doode wrote: Fri Sep 01, 2023 2:10 pmIt's been pretty quiet from them about this.MrEJ42 wrote: Fri Sep 01, 2023 3:06 amIt worries me that they haven't found a solution by now.neglectedpets wrote: Thu Aug 31, 2023 10:50 pm I had to send my BDR-XS07UHD in for service as the drive stopped functioning after only 8 months. I hadn't heard about the new Pioneer firmware issue until the last few days. I just got the drive back today and it has the dreaded 1.03 firmware so I'm dead in the water now I guess. Pretty bummed. I hope there's a solution soon, otherwise I'll be buying a new drive.
I had bought a second BDR-S13UBK and it came with a newer firmware. Strongly considering returning it unless we know reasonably sure there will be a fix in the future. It is unopened and unused to I am not screwing over the merchant.
randomuser001
Yeah I'm in the same boat Krawk. I bought a new Pioneer blu ray drive. I don't want to screw over the merchant and return it since it's honestly perfectly good. I would love to know if they had a rough estimate on if they will be able to get a fix and if so around when.
Good choice for now.Krawk wrote: Wed Sep 06, 2023 9:10 pm I had bought a second BDR-S13UBK and it came with a newer firmware. Strongly considering returning it unless we know reasonably sure there will be a fix in the future. It is unopened and unused to I am not screwing over the merchant.
palindromico
Hello everyone.
I own a Pioneer BDR-XS07UHD which had the FW suitable for acquiring UHD BRDs but which I, very intelligently, updated to the latest version... (I wasn't aware of the problem, I discovered it a few days ago)
I retrieved the link to the FWs prior to 1.03 from the Pioneer website, and downloaded them, but I wonder: is it that simple to downgrade the FW? Maybe I'm paranoid but... has anyone tried?
I don't want to make the player completely unusable, since I'm also backing up my non-UHD BRDs...
Thanks in advance!!!
Marco
Marco
You are out of luck until there is a solution.
palindromico
Yes... I imagined: therefore (as I feared) it is impossible to downgrade the FW...
I really was an idiot... My fault.
TeddyRaspin
It is possible, you only have to wait patiently.
Hello all,
Noob here. can someone point me in the direction to patched UHD enabling firmware for my drive:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.00
Serial number: SGDL000006WL
Firmware date: 2019-01-10
Highest AACS version: 19
Drive platform: RS8F01
Firmware version: 1.00/ID43
OS device name: F:
Revision: 1.00
you are good as is do not update it leave it. if its not working you have a different issue like your hk not downloadingmickstaa wrote: Tue Sep 12, 2023 10:40 am Hello all,
OS device name: F:
Revision: 1.00
