Looking for advice. Is it helpful to have diverse drive models?
TomB19
Post by TomB19 »
I have a pair of identical LG WH16NS40 drives. They work well with LibreDrive v1.02.
Oddly, the second drive always worked better than the first drive until I cleaned the laser lens in each drive. Now they both work equally well.
Still, there is the odd disk I cannot read.
Would it be helpful to have a different model drive as an option for disks that do not read in these drives? I understand there is only one drive manufacturer and the optics are probably all common so perhaps it would not be helpful?
Re: Looking for advice. Is it helpful to have diverse drive models?
TomB19 wrote: Thu Aug 31, 2023 8:44 pm I have a pair of identical LG WH16NS40 drives. They work well with LibreDrive v1.02.
There is more than one drive manufacturer and yes it is helpful to have different models/brands. I suggest you add a Pioneer drive to your collection. You can get one from a seller here in your region.
As I understand it, the ASUS drives are rebranded LG drives.
The LG BU40N is different hardware than the 'standard' LG/ASUS desktop drive. And as MartyMcNuts mentioned, Pioneer's hardware is unique to Pioneer. Both are well regarded.
I have 3 different optical drives, all different, and I find the diversity of hardware does produce different results. With troublesome discs, usually at least one of the drives will work.
TomB19
Post by TomB19 »
I appreciate the help, gentlemen.
