chronomac
Post
by chronomac » Thu Aug 24, 2023 4:14 pm
RESET_9999 wrote: ↑Mon Aug 21, 2023 10:26 pm
chronomac wrote: ↑Mon Aug 21, 2023 10:07 pm
What's the maximum number you can use?
the script exports a screenshot every 2000 frames starting at frame 1000. (1000-3000-5000-7000-9000-11000 etc..)
So it depends on your input length.
you could remove a 0 in %%i000 around line 11495 and that would allow a lot more screenshots to be extracted.
for /L %%i in (1,2,%frame_number%) do (
echo LoadPlugin("%ffms2%"^) > "%TEMP%%%i.avs"
echo FFVideoSource("%filepath%%filename%%fileext%", cachefile="%TEMP%1.ffindex"^) >> "%TEMP%%%i.avs"
echo scriptClip(""^" >> "%TEMP%%%i.avs"
echo subtitle("%filename%", size=14, align=7, 4, 25, text_color=$606060^) >> "%TEMP%%%i.avs"
echo subtitle("Resolution: " + string(width^) + " x " + string(height^) + " @ " + string(framerate^), size=14, align=7, 4, 40, text_color=$606060^) >> "%TEMP%%%i.avs"
echo subtitle("Frame: %%i000", size=14, align=7, 4, 55, text_color=$606060^) >> "%TEMP%%%i.avs"
echo subtitle("Picture type: " + Chr(FFPICT_TYPE^), size=14, align=7, 4, 70, text_color=$606060^) >> "%TEMP%%%i.avs"
echo ""^"^) >> "%TEMP%%%i.avs"
echo trim(%%i000,%%i000^) >> "%TEMP%%%i.avs"
change it to
echo subtitle("Frame: %%i00", size=14, align=7, 4, 55, text_color=$606060^) >> "%TEMP%%%i.avs"
echo trim(%%i00,%%i00^) >> "%TEMP%%%i.avs"
Also line 11528 and 11626:
echo noms_images = ['%filename%_Frame_%%i00.tiff'] >> "%TEMP%gamut_map.py"
echo noms_images = ['%filename%_Frame_%%i00.tiff'] >> "%TEMP%heat_map.py"
Thanks so much for this info.
Another question, unrelated: theoretically, would it be possible to calculate the number of pixels in a frame that extend into P3 and Rec.2020? If so, could you do that for a whole movie? The gamut visualizations are helpful for seeing extensions past Rec. 709 but it would be great to get a more objective, definable number for a movie (ie. 10% of the movie is in the WCG).
Post
by RESET_9999 » Thu Aug 24, 2023 7:13 pm
chronomac wrote: ↑Thu Aug 24, 2023 4:14 pm
yes, it's probably possible but I didn't do that Python script so I don't know. You could ask the author @dorian in this thread:
https://forum.blu-ray.com/showthread.ph ... 42&page=35
chronomac
Post
by chronomac » Tue Aug 29, 2023 1:23 pm
RESET_9999 wrote: ↑Thu Aug 24, 2023 7:13 pm
I'll reach out over there.
Another unrelated question, if you don't mind: I recently updated the script and now whenever I use the 4-2 path, to convert a profile 7 DV MKV to profile 8, the output is just a .hevc file. Is that normal? It used to be a fully fledged MKV. To be clear, I muxed that .hevc with the audio, chapters and subtitles of the original MKV without an issue. Plays back fine, as far as I can tell. I just didn't know if the process had changed or if I'm missing a tool for that last step.
Post
by RESET_9999 » Tue Aug 29, 2023 2:16 pm
chronomac wrote: ↑Tue Aug 29, 2023 1:23 pm
It means the muxing failed. I just tried with a sample and everything is fine on my end so I don't know and without any info about the input or the script cmd , there's not much I can do.
You could try the latest beta.
Drag and drop a P7 MKV file and press enter...
"D:\samples\P7 THD DTS SRT PGS (2021).mkv"
Input tracks info:
index=1
codec_name=truehd
channel_layout=7.1
TAG:language=eng
index=2
codec_name=dts
channel_layout=7.1
TAG:language=eng
index=3
codec_name=ac3
channel_layout=5.1(side)
TAG:language=eng
index=4
codec_name=ac3
TAG:language=cze
index=5
codec_name=dts
TAG:language=fre
index=6
codec_name=ac3
TAG:language=ger
index=7
codec_name=ac3
TAG:language=hun
index=8
codec_name=dts
TAG:language=ita
index=9
codec_name=ac3
TAG:language=por
index=10
codec_name=ac3
TAG:language=spa
index=11
codec_name=dts
TAG:language=spa
index=12
codec_name=ac3
TAG:language=tha
Do you want to convert the audio to DDP? (y or n default=n) if input is 7.1, a 2nd window will popup, DO NOT CLOSE IT!
* INPUT INFO *
--> L5 Left offset: 0
--> L5 Right offset: 0
--> L5 Top offset: 280
--> L5 Bottom offset: 280
--> DoVi Profile: MEL
--> L2 trims: YES (100nits)
--> DoVi source min_pq: 50 nits
--> DoVi source max_pq: 4000 nits
--> HDR10 BL input MDL: "min: 0.0050 cd/m2, max: 4000 cd/m2"
Do you want to edit L5... y or n ? and/or press enter...
reading input tracks format/id/language...
done.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\DoVi_Scripts\TEMP_folder\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Extracting track 1 with the CodecID 'A_TRUEHD' to the file 'D:\DoVi_Scripts\TEMP_folder\au.thd'. Container format: TrueHD
Extracting track 13 with the CodecID 'S_TEXT/UTF8' to the file 'D:\DoVi_Scripts\TEMP_folder\en14.srt'. Container format: SRT text subtitles
Extracting track 14 with the CodecID 'S_TEXT/UTF8' to the file 'D:\DoVi_Scripts\TEMP_folder\en15.srt'. Container format: SRT text subtitles
Extracting track 15 with the CodecID 'S_HDMV/PGS' to the file 'D:\DoVi_Scripts\TEMP_folder\en16.pgs'. Container format: SUP
Extracting track 16 with the CodecID 'S_HDMV/PGS' to the file 'D:\DoVi_Scripts\TEMP_folder\en17.pgs'. Container format: SUP
Extracting track 17 with the CodecID 'S_HDMV/PGS' to the file 'D:\DoVi_Scripts\TEMP_folder\en18.pgs'. Container format: SUP
Extracting track 18 with the CodecID 'S_HDMV/PGS' to the file 'D:\DoVi_Scripts\TEMP_folder\en19.pgs'. Container format: SUP
Progress: 100%
converting and injecting RPU...
Rewriting file with interleaved EL NALUs..
mkvmerge v79.0 ('Funeral Pyres') 64-bit
'D:\DoVi_Scripts\P7 THD DTS SRT PGS (2021)_P8.hevc': Using the demultiplexer for the format 'HEVC/H.265'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv': Using the demultiplexer for the format 'Matroska'.
'D:\DoVi_Scripts\P7 THD DTS SRT PGS (2021)_P8.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 1: Using the output module for the format 'TrueHD'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 2: Using the output module for the format 'DTS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 3: Using the output module for the format 'AC-3'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 4: Using the output module for the format 'AC-3'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 5: Using the output module for the format 'DTS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 6: Using the output module for the format 'AC-3'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 7: Using the output module for the format 'AC-3'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 8: Using the output module for the format 'DTS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 9: Using the output module for the format 'AC-3'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 10: Using the output module for the format 'AC-3'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 11: Using the output module for the format 'DTS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 12: Using the output module for the format 'AC-3'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 13: Using the output module for the format 'text subtitles'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 14: Using the output module for the format 'text subtitles'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 15: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 16: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 17: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 18: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 19: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 20: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 21: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 22: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 23: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 24: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 25: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 26: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 27: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 28: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 29: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 30: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 31: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 32: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 33: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 34: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 35: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 36: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 37: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 38: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 39: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 40: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 41: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 42: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 43: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 44: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 45: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 46: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 47: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 48: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 49: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 50: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 51: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 52: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 53: Using the output module for the format 'HDMV PGS'.
'D:\samples\P7 THD DTS SRT PGS (2021).mkv' track 54: Using the output module for the format 'HDMV PGS'.
The file 'D:\DoVi_Scripts\P7 THD DTS SRT PGS (2021).DV.mkv' has been opened for writing.
'D:\DoVi_Scripts\P7 THD DTS SRT PGS (2021)_P8.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 3840/2160.
The cue entries (the index) are being written...
Multiplexing took 22 seconds.
"The script has completed"
Appuyez sur une touche pour continuer...
chronomac
Post
by chronomac » Tue Aug 29, 2023 4:02 pm
RESET_9999 wrote: ↑Tue Aug 29, 2023 2:16 pm
Input tracks info:
index=1
codec_name=truehd
channel_layout=7.1
TAG:language=eng
index=2
codec_name=dts
channel_layout=7.1
TAG:language=eng
index=3
codec_name=ac3
TAG:language=eng
index=4
codec_name=ac3
TAG:language=cze
index=5
codec_name=dts
TAG:language=fre
index=6
codec_name=ac3
TAG:language=ger
index=7
codec_name=ac3
TAG:language=hun
index=8
codec_name=dts
TAG:language=ita
index=9
codec_name=ac3
TAG:language=por
index=10
codec_name=ac3
TAG:language=spa
index=11
codec_name=dts
TAG:language=spa
index=12
codec_name=ac3
TAG:language=tha
* INPUT INFO *
done.
Progress: 100%
The newest beta worked perfectly:
"C:\Users\user\Downloads\Video.mkv"
Input tracks info:
index=1
codec_name=dts
TAG:language=eng
index=2
codec_name=dts
TAG:language=eng
n
* INPUT INFO *
--> L5 Top offset: 120
--> L5 Bottom offset: 120
--> L2 trims: YES (100nits) (600nits) (1000nits)
--> DoVi source min_pq: 1 nits
--> DoVi source max_pq: 1000 nits
--> HDR10 BL input MDL: "min: 0.0001 cd/m2, max: 1000 cd/m2"
n
done.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'C:\Users\user\Desktop\DoVi_Scripts\TEMP_folder\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Extracting track 1 with the CodecID 'A_DTS' to the file 'C:\Users\user\Desktop\DoVi_Scripts\TEMP_folder\au.dts'. Container format: Digital Theater System (DTS)
Extracting track 3 with the CodecID 'S_HDMV/PGS' to the file 'C:\Users\user\Desktop\DoVi_Scripts\TEMP_folder\en4.pgs'. Container format: SUP
Progress: 100%
mkvmerge v76.0 ('Celebration') 64-bit
'C:\Users\user\Desktop\DoVi_Scripts\Video_P8.hevc': Using the demultiplexer for the format 'HEVC/H.265'.
'C:\Users\user\Downloads\Video.mkv': Using the demultiplexer for the format 'Matroska'.
'C:\Users\user\Desktop\DoVi_Scripts\Video_P8.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'.
'C:\Users\user\Downloads\Video.mkv' track 1: Using the output module for the format 'DTS'.
'C:\Users\user\Downloads\Video.mkv' track 2: Using the output module for the format 'DTS'.
'C:\Users\user\Downloads\Video.mkv' track 3: Using the output module for the format 'HDMV PGS'.
The file 'C:\Users\user\Desktop\DoVi_Scripts\Video.DV.mkv' has been opened for writing.
'C:\Users\user\Desktop\DoVi_Scripts\Video_P8.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 3840/2160.
Multiplexing took 1 minute 12 seconds.
fransalas
Post
by fransalas » Wed Aug 30, 2023 9:04 am
good afternoon, RESET 9999 I can't find the HDR 10 plus Injector/Extractor option, your the latest beta
Post
by RESET_9999 » Wed Aug 30, 2023 12:05 pm
fransalas wrote: ↑Wed Aug 30, 2023 9:04 am
I moved the workflows I use the most in the main menu so the order changed a bit but it's still there: 8-4
fransalas
Post
by fransalas » Wed Aug 30, 2023 2:19 pm
Thank you very much RESET_9999, I already found it..
greetings
Gatorman
Post
by Gatorman » Wed Aug 30, 2023 9:32 pm
RESET_9999 wrote: ↑Thu Jun 22, 2023 7:19 pm
IMO, the L2 trims can only be done/edited by the colorist/director so for our Resolve generated RPU, I recommend removing or overwriting the automatic trims otherwise they can make bright content very dark and dark content brighter which might not be the intended look.
Is this still your preferred method with (3-1)?
Post
by RESET_9999 » Wed Aug 30, 2023 10:05 pm
Gatorman wrote: ↑Wed Aug 30, 2023 9:32 pm
Yes, the L2 trims are removed by default in (3-1). I watched a couple of CM_analyze generated movies and it looks better than ever.
The latest Dolby algo is much better than the old one that Resolve uses and the fact that we can use HRD10plus scene cuts(or any official ones) is great. example:
https://slow.pics/c/3EyCFPu9
thirdmoon
Post
by thirdmoon » Thu Aug 31, 2023 7:45 am
RESET_9999 wrote: ↑Wed Aug 30, 2023 10:05 pm
Is there any way to speed up the process of 3-1. For me it is literally 10x slower than DaVinci. (30min DaVinci, 7-8hour on 3-1)
Post
by RESET_9999 » Thu Aug 31, 2023 10:58 am
thirdmoon wrote: ↑Thu Aug 31, 2023 7:45 am
The only way is to not touch your PC while CM is running. It takes about 1h and the speed goes from 0.050 to 0.400
If I work on my PC at the same time, it can take 6h indeed. speed goes from 0.050 to 2.5
skull88
Post
by skull88 » Thu Aug 31, 2023 2:33 pm
The question is how much do you care about the difference between cm_analyze vs. Resolve algorithm output in the final image, or even the (sometimes flawed/lazy/inaccurate) retail DV metadata, which is how 99.9% of the world sees the films, lol. Have you A/B tested a sample or movie yet? I find CM is best at this point, but Resolve is a close 2nd and in a blind-test, you may even end up preferring one or the other for a particular film. RESET is rightly focused on accuracy and upholding the original intent of the colourist/filmmakers as much as possible, but we're still working with approximation and no full Dolby Vision license, keep in mind. As far as the question of speed, Dolby obviously expects people to have dedicated server or workstation for running their pro tools, so your call how much time/resources you want to dedicate to this entire process, especially if you don't get much enjoyment out of the technical details/testing/troubleshooting aspect.
In the end, patience is the biggest virtue you'll have with all this, no full automation is possible without sacrificing quality control and not understanding the tools or workflows can lead to errors/issues too. Cheers!
jlpsvk
Post
by jlpsvk » Thu Aug 31, 2023 2:44 pm
can't agree more..
right now, only flaw is, that latest cm_analyze is buggy and on cuda it's slowing down rapidly.
or in other words, starting to use less and less gpu power... watched it recently, started at 26% GPU usage (LAST FRAME: 0.05s), and in one third of the analysis, it was down to 12% (LAST FRAME: 0.6s).
GPU used was GTX 1660 SUPER
jlpsvk
Post
by jlpsvk » Thu Aug 31, 2023 2:48 pm
regarding slowdown of cm_analyze... has anybody tried nVidia's Studio driver????
