CPU requirements for bluray
Roybluray
I have a AMD FX-6100 - FX-Series Zambezi 6-Core 3.3 GHz Socket AM3+
Can I use a Bluray drive for ripping just Bluray discs or do I need an Intel CPU? Could not find any CPU requiremnts just OS requirements.
Was looking at this drive ASUS BW-16D1HT - ultra-fast 16X Blu-ray burner
Re: CPU requirements for bluray
Essentially any CPU can be used.Roybluray wrote: Mon Aug 28, 2023 9:30 am I have a AMD FX-6100 - FX-Series Zambezi 6-Core 3.3 GHz Socket AM3+
flojo
The CPU requirements are not known but, I *think* I have a Athlon 64 X2 in a machine that I used makemkvcon on, at least I'm pretty sure that's what it was. I know for a fact that it works on an i5-3570 CPU, which is from that same period and has basically the same instruction set (minus VT-x).
Roybluray
I don't know about Blu-ray but Intel is dropping their SXG from 11 and 12 Gen processors to decode UHD 4k.
Guess I will be looking for a new computer with older Intel Gen processor.
all of that is completely irrelevant with makemkv you dont need to worry about that cpu you have to rip or play 4K UHD movies you just need a bluray drive with the correct firmware.Roybluray wrote: Tue Aug 29, 2023 9:52 pm I don't know about Blu-ray but Intel is dropping their SXG from 11 and 12 Gen processors to decode UHD 4k.
Roybluray
Guess there is more to learn then. I'm just now getting into this to be able to play and rip Blu-ray and 4k.
Looked at many Blu-ray/4k drives, pioneer and Asus.
Could you suggest some drives to go with?
Roybluray
I double checked my CPU last night and mine is a little better.
AMD FX 6300 6 cores at 3.5 ghz
Roybluray
Sorry, I just saw your guide on UHD drives to get.
i recommend the pioneers very hard to get a working one with the right firmware though but i have them
Roybluray
I'm interested in getting one from you. Do have the Pioneer Sliver in stock ready to ship?
Forum rules don't allow transactions to happen on the forum. Email is a better choice for that stuff. His email is in his signature.Roybluray wrote: Wed Aug 30, 2023 1:33 am I'm interested in getting one from you. Do have the Pioneer Sliver in stock ready to ship?
Roybluray
Sorry, I am emailing you now.
