CPU requirements for bluray
Roybluray
Post by Roybluray » Mon Aug 28, 2023 9:30 am
I have a AMD FX-6100 - FX-Series Zambezi 6-Core 3.3 GHz Socket AM3+
Can I use a Bluray drive for ripping just Bluray discs or do I need an Intel CPU? Could not find any CPU requiremnts just OS requirements.
Was looking at this drive ASUS BW-16D1HT - ultra-fast 16X Blu-ray burner
Re: CPU requirements for bluray
Post by MartyMcNuts » Mon Aug 28, 2023 11:03 am
Roybluray wrote: Mon Aug 28, 2023 9:30 am I have a AMD FX-6100 - FX-Series Zambezi 6-Core 3.3 GHz Socket AM3+
Essentially any CPU can be used.
flojo
Post by flojo » Mon Aug 28, 2023 12:40 pm
The CPU requirements are not known but, I *think* I have a Athlon 64 X2 in a machine that I used makemkvcon on, at least I'm pretty sure that's what it was. I know for a fact that it works on an i5-3570 CPU, which is from that same period and has basically the same instruction set (minus VT-x).
Roybluray
Post by Roybluray » Tue Aug 29, 2023 9:52 pm
I don't know about Blu-ray but Intel is dropping their SXG from 11 and 12 Gen processors to decode UHD 4k.
Guess I will be looking for a new computer with older Intel Gen processor.
Post by Billycar11 » Tue Aug 29, 2023 10:48 pm
Roybluray wrote: Tue Aug 29, 2023 9:52 pm I don't know about Blu-ray but Intel is dropping their SXG from 11 and 12 Gen processors to decode UHD 4k.
all of that is completely irrelevant with makemkv you dont need to worry about that cpu you have to rip or play 4K UHD movies you just need a bluray drive with the correct firmware.
Roybluray
Post by Roybluray » Tue Aug 29, 2023 11:17 pm
Guess there is more to learn then. I'm just now getting into this to be able to play and rip Blu-ray and 4k.
Looked at many Blu-ray/4k drives, pioneer and Asus.
Could you suggest some drives to go with?
Roybluray
Post by Roybluray » Tue Aug 29, 2023 11:23 pm
I double checked my CPU last night and mine is a little better.
AMD FX 6300 6 cores at 3.5 ghz
Roybluray
Post by Roybluray » Tue Aug 29, 2023 11:44 pm
Sorry, I just saw your guide on UHD drives to get.
Post by Billycar11 » Wed Aug 30, 2023 12:40 am
Roybluray wrote: Tue Aug 29, 2023 11:44 pm Sorry, I just saw your guide on UHD drives to get.
i recommend the pioneers very hard to get a working one with the right firmware though but i have them
Roybluray
Post by Roybluray » Wed Aug 30, 2023 1:33 am
I'm interested in getting one from you. Do have the Pioneer Sliver in stock ready to ship?
Post by dcoke22 » Wed Aug 30, 2023 1:54 am
Roybluray wrote: Wed Aug 30, 2023 1:33 am I'm interested in getting one from you. Do have the Pioneer Sliver in stock ready to ship?
Forum rules don't allow transactions to happen on the forum. Email is a better choice for that stuff. His email is in his signature.
Roybluray
Post by Roybluray » Wed Aug 30, 2023 2:03 am
Sorry, I am emailing you now.
