CPU requirements for bluray
Roybluray
Post by Roybluray »
I have a AMD FX-6100 - FX-Series Zambezi 6-Core 3.3 GHz Socket AM3+
Can I use a Bluray drive for ripping just Bluray discs or do I need an Intel CPU? Could not find any CPU requiremnts just OS requirements.
Was looking at this drive ASUS BW-16D1HT - ultra-fast 16X Blu-ray burner
Re: CPU requirements for bluray
Roybluray wrote: Mon Aug 28, 2023 9:30 am I have a AMD FX-6100 - FX-Series Zambezi 6-Core 3.3 GHz Socket AM3+
Essentially any CPU can be used.
flojo
Post by flojo »
The CPU requirements are not known but, I *think* I have a Athlon 64 X2 in a machine that I used makemkvcon on, at least I'm pretty sure that's what it was. I know for a fact that it works on an i5-3570 CPU, which is from that same period and has basically the same instruction set (minus VT-x).
Roybluray
Post by Roybluray »
I don't know about Blu-ray but Intel is dropping their SXG from 11 and 12 Gen processors to decode UHD 4k.
Guess I will be looking for a new computer with older Intel Gen processor.
Roybluray wrote: Tue Aug 29, 2023 9:52 pm I don't know about Blu-ray but Intel is dropping their SXG from 11 and 12 Gen processors to decode UHD 4k.
all of that is completely irrelevant with makemkv you dont need to worry about that cpu you have to rip or play 4K UHD movies you just need a bluray drive with the correct firmware.
Roybluray
Post by Roybluray »
Guess there is more to learn then. I'm just now getting into this to be able to play and rip Blu-ray and 4k.
Looked at many Blu-ray/4k drives, pioneer and Asus.
Could you suggest some drives to go with?
Roybluray
Post by Roybluray »
I double checked my CPU last night and mine is a little better.
AMD FX 6300 6 cores at 3.5 ghz
Roybluray
Post by Roybluray »
Sorry, I just saw your guide on UHD drives to get.
Roybluray wrote: Tue Aug 29, 2023 11:44 pm Sorry, I just saw your guide on UHD drives to get.
i recommend the pioneers very hard to get a working one with the right firmware though but i have them
Roybluray
Post by Roybluray »
I'm interested in getting one from you. Do have the Pioneer Sliver in stock ready to ship?
Roybluray wrote: Wed Aug 30, 2023 1:33 am I'm interested in getting one from you. Do have the Pioneer Sliver in stock ready to ship?
Forum rules don't allow transactions to happen on the forum. Email is a better choice for that stuff. His email is in his signature.
Roybluray
Post by Roybluray »
Sorry, I am emailing you now.
