CPU requirements for bluray
Roybluray
Post by Roybluray »
I have a AMD FX-6100 - FX-Series Zambezi 6-Core 3.3 GHz Socket AM3+
Can I use a Bluray drive for ripping just Bluray discs or do I need an Intel CPU? Could not find any CPU requiremnts just OS requirements.
Was looking at this drive ASUS BW-16D1HT - ultra-fast 16X Blu-ray burner
Re: CPU requirements for bluray
Roybluray wrote:
Mon Aug 28, 2023 9:30 am
Essentially any CPU can be used.
flojo
Post by flojo »
The CPU requirements are not known but, I *think* I have a Athlon 64 X2 in a machine that I used makemkvcon on, at least I'm pretty sure that's what it was. I know for a fact that it works on an i5-3570 CPU, which is from that same period and has basically the same instruction set (minus VT-x).
Roybluray
Post by Roybluray »
I don't know about Blu-ray but Intel is dropping their SXG from 11 and 12 Gen processors to decode UHD 4k.
Guess I will be looking for a new computer with older Intel Gen processor.
Roybluray wrote:
Tue Aug 29, 2023 9:52 pm
all of that is completely irrelevant with makemkv you dont need to worry about that cpu you have to rip or play 4K UHD movies you just need a bluray drive with the correct firmware.
Roybluray
Post by Roybluray »
Guess there is more to learn then. I'm just now getting into this to be able to play and rip Blu-ray and 4k.
Looked at many Blu-ray/4k drives, pioneer and Asus.
Could you suggest some drives to go with?
Roybluray
Post by Roybluray »
I double checked my CPU last night and mine is a little better.
AMD FX 6300 6 cores at 3.5 ghz
Roybluray
Post by Roybluray »
Sorry, I just saw your guide on UHD drives to get.
Roybluray wrote:
Tue Aug 29, 2023 11:44 pm
i recommend the pioneers very hard to get a working one with the right firmware though but i have them
Roybluray
Post by Roybluray »
I'm interested in getting one from you. Do have the Pioneer Sliver in stock ready to ship?
Roybluray wrote:
Wed Aug 30, 2023 1:33 am
Forum rules don't allow transactions to happen on the forum. Email is a better choice for that stuff. His email is in his signature.
Roybluray
Post by Roybluray »
Sorry, I am emailing you now.
