Pioneer BDR-XD08B
ThatOneGuyOverThere
Pioneer BDR-XD08B
Hello I'm new and have purchased this pioneer drive. I have mkv downloaded and was wondering if someone could point me in the right direction on how to get the drive ready to rip 4k blu rays.
I'm a bit clueless with this. Seems like it reads blu rays right away but 4k it says no disc. Any help is appreciated, thanks!
Re: Pioneer BDR-XD08B
What does MakeMKV say about the drive? A number of Pioneer drives manufactured after December 2022 are currently stalled as far as 4K support is concerned.
Also, that model is not a UHD drive so cannot rip UHD without being cross-flashed.ThatOneGuyOverThere wrote: Tue Aug 22, 2023 11:17 pm Hello I'm new and have purchased this pioneer drive. I have mkv downloaded and was wondering if someone could point me in the right direction on how to get the drive ready to rip 4k blu rays.
ThatOneGuyOverThere
So the one I got from amazon was manufactured in November 2022.
Can this be cross flashed or whatever? Or did I waste my money?
Is there a drive that will just work out of the box for ripping my 4k discs?
Can't say until you show us your MakeMKV info or at least tell us the firmware date.ThatOneGuyOverThere wrote: Wed Aug 23, 2023 11:11 pm So the one I got from amazon was manufactured in November 2022.
ThatOneGuyOverThere
It says it's revision 1.01
It's firmware date is 2022-10-11
It says firmware is original unpatched.
ThatOneGuyOverThere
Was this the info you needed in my last post?
ThatOneGuyOverThere wrote: Fri Aug 25, 2023 10:49 pm It says it's revision 1.01
It should work. You were to supposed to run Makemkv and copy&paste what is shown on the right side of the screen. So we know. But just try an UHD. It should work.
It would need to be cross-flashed to the UHD model to be able to rip UHD discs.
ThatOneGuyOverThere
Ok so how do I crossflash the drive? Is there a program I need or something?
G-doggy
Hello, I have the exact same model and also would like to know how to crossflash. Or whatever else to get it to read uhd.
Check PMG-doggy wrote: Fri Nov 17, 2023 4:37 pm Hello, I have the exact same model and also would like to know how to crossflash. Or whatever else to get it to read uhd.
Psycomo
I also have this drive. How do I crossflash?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.01
Serial number: [redacted]
Firmware date: 2022-10-11
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.01
OS device name: E:
Revision: 1.01
Read your PM.Psycomo wrote: Sun Aug 11, 2024 12:34 pm I also have this drive. How do I crossflash?
OS device name: E:
Revision: 1.01
