can't rip piyo from beachbody
warwolf7
Post by warwolf7 »
I'm trying to rip dvd : PIYO from beachbody
I tried with disc1 , it failed ,than tried the disc2 and failed as well
type :dvd
label PiYO_DISC2
protection : CSS/CPPM
I get this error
[autodiscripper] [makemkvcon] MakeMKV v1.17.4 linux(x64-release) started
[autodiscripper] [makemkvcon] Debug logging enabled
[autodiscripper] [makemkvcon] Current operation: Scanning CD-ROM devices
[autodiscripper] [makemkvcon] Current action: Scanning CD-ROM devices
[autodiscripper] [makemkvcon] Current progress - 0%, Total progress - 0%
[autodiscripper] [makemkvcon] DEBUG: Code 0 at t>GEv(0Ut;[yI:Bv4:-]D:29393631
[autodiscripper] [makemkvcon] DEBUG: Code 2 at ye;l{s_mYTRE71}{#4v0:213129892
[autodiscripper] [makemkvcon] DEBUG: Code 0 at E>N]4oG#d08A[Ax:213130329
[autodiscripper] [makemkvcon] Current progress - 100%, Total progress - 0%
[autodiscripper] [makemkvcon] Current progress - 100%, Total progress - 100%
[autodiscripper] [makemkvcon] Current progress - 0%, Total progress - 100%
[autodiscripper] [makemkvcon] Using LibreDrive mode (v06.3 id=7FA2657C7667)
[autodiscripper] [makemkvcon] Current operation: Opening DVD disc
[autodiscripper] [makemkvcon] Using direct disc access mode
[autodiscripper] [makemkvcon] Current action: Processing title sets
[autodiscripper] [makemkvcon] Calculated BUP offset for VTS #0 does not match one in IFO header.
[autodiscripper] [makemkvcon] DEBUG: Code 0 at 3n5q#[G$W8Bm5W:29400071
[autodiscripper] [makemkvcon] IFO file for VTS #0 is corrupt
[autodiscripper] [makemkvcon] DEBUG: Code 0 at EbFzoS2txlI[YW(?S:121262854
I also tried all the different DVD structurure removal method options, but they all failed.
Other info : I can rip pretty much any other dvd and blueray just fine. so makeMKV is working fine for other title
I read that those beachbody are problematic with makeMKV, is there a workaround?
Thank you
