Bought a LG BU40N, can't find any "SVC NS50+" label.
Yazze
#1 Post by Yazze » Mon Sep 06, 2021 11:42 am
Noob here.
As the title says can't find anything about a SVC label on the drive. Does that mean I'm screwed? Or am i just blind? Thanks for the help!
(Attached image of the label)
Re: Bought a LG BU40N, can't find any "SVC NS50+" label.
#2 Post by MartyMcNuts » Tue Sep 07, 2021 1:06 am
Yazze wrote: Mon Sep 06, 2021 11:42 am Noob here.
BU40N's are a different beast and do not have the SVC NS50+ requirement. Looking at the pic, your's looks good. Has 1.04 (encrypted) firmware, so use "enc" when flashing the very first time.
Yazze
#3 Post by Yazze » Tue Sep 07, 2021 8:25 am
MartyMcNuts wrote: Tue Sep 07, 2021 1:06 am
I see, appreciate the help! Hopefully everything goes smoothly. :O)
OldMovieFan
#4 Post by OldMovieFan » Sun Aug 27, 2023 3:58 pm
I have an LG BP50NB40 and it says:
SVC NB40
I guess I'm screwed then...?
Manufactured November 2020.
#5 Post by MartyMcNuts » Sun Aug 27, 2023 6:30 pm
OldMovieFan wrote: Sun Aug 27, 2023 3:58 pm I have an LG BP50NB40 and it says:
SVC NB40
Nah, you should be ok to flash it. I've flashed plenty of those (with NB40). The main thing with those is that the manufacture date is 2020.
OldMovieFan
#6 Post by OldMovieFan » Mon Aug 28, 2023 3:05 am
Okay, thanks. Good news then.
I have looked at the guide and saw this:
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
if using command line add "full" after rawflash
I don't really understand it. It's not self-explanatory. Does this mean I have to flash it more than once to go from BP50NB40 to BP50NB40-NB50-1.03MK and then flash it again to get to BP60NB10 1.02MK or 1.00MK?
Presumably at that point it will work? If not then what does the rest mean?
I watched this video, which gave me some idea:
https://www.youtube.com/watch?v=jyQV1aPlbow
And just to make it more complicated, mine doesn't have a drive letter because it's a USB drive. The 'F' assignation doesn't show in Windows Explorer unless there's a disc in it.
This is what my MakeMKV opening page looks like:
OS device name: F:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: XXXXXXXXXXXXX
Highest AACS version: 78
Harware support: Yes
Firmware support: No
Firmware version: 1.03
#7 Post by MartyMcNuts » Mon Aug 28, 2023 5:22 am
OldMovieFan wrote: Mon Aug 28, 2023 3:05 am Okay, thanks. Good news then.
OS device name: F:
Revision: 1.03
Download SDFTool Flasher and the firmware pack if you haven't already. Use SDFtool Flasher and follow the below steps:
1. Flash BP50NB40 (NB50) 1.03-MK
2. Now try flashing BU40N 1.00. If the drive shows as BU40N 1.00, your done. If it doesn't, perform the below step:
3. In SDFtool Flasher, select the Recovery option. In the popup window, select the BP50NB40 (NB50) 1.03-MK that you flashed in step 1. In the firmware selection dropdown box, select BU40N 1.00. Press START to flash. This does take a minute so just wait for SDFTool Flasher to say "Ready...", then you are done.
OldMovieFan
#8 Post by OldMovieFan » Mon Aug 28, 2023 8:30 am
Thanks so much for that.
I tried first with a 4K of '1917'. It initially took a very long time to read the disc and I though it was probably a bad sign because that's usually what happens when it can't read a Blu-ray. Eventually it could read the disc but there were a lot of reports of 'Incompatible media'. So it looks like the flash worked but although the drive was able to read the disc, it couldn't open it.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0797124CB9213C70BC2B64F9810E23A1324 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Before responding further, I tried a different disc, this time 'Batman Begins' and it was able to open and read it. Ripped directly to a NAS over WiFi, that 139 minute 75GB movie took about 55:30.
Many thanks for making this so simple.
OldMovieFan
#9 Post by OldMovieFan » Tue Aug 29, 2023 10:59 am
Just an update: at third attempt, I can now rip '1917'.
Must have been a dirty disc or something.
Thanks again.
#10 Post by MartyMcNuts » Tue Aug 29, 2023 11:49 pm
OldMovieFan wrote: Tue Aug 29, 2023 10:59 am Just an update: at third attempt, I can now rip '1917'.
Thanks again.
Yes, it happens quite often with UHD discs. Just give them a good clean before trying to rip again.
