Bloodsport 4K UHD UK release wont rip
cabwiz
Post by cabwiz »
Hi, I just emailed a request to assist with this new release as it won't rip. I provided the following info and can anyone confirm if i sent the right info to assist:
MakeMKV v1.17.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=96929CF53B04)
Saved AACS dump file as C:\Users\1badv/.MakeMKV/MKB20_v77_Bloodsport_2E28.tgz
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: M6BJ5980503
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Highest AACS version: 77
Firmware version: 3.02
Disc Information
Label: BLOODSPORT DE UK
Timestamp: 2023-06-30 12:57:49
Protection: AACS2.0/C v77
Data capacity: 77.92 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Re: Bloodsport 4K UHD UK release wont rip
Did you email the dump file to svq@makemkv.com?
UHD FAQ
cabwiz
Post by cabwiz »
i emailed everything above to that email address. Are you saying all i needed to send was this info:
You need to find that actual file on your computer and attach it to an email sent to the address I posted.
The author of MakeMKV will use that .tgz file to generate a key that can decrypt the UHD in question. After the key is generated, it'll be available on the internet for MakeMKV to download (automatically, in the background, when it is needed).
After the dump is emailed, wait a few days and try to rip your disc again. If they key is available, MakeMKV will download it, and things will proceed as normal. If it isn't available, wait a few more days and try again.
cabwiz
Post by cabwiz »
Thank you, just sent the file.
cabwiz
Post by cabwiz »
Thank you so much, movie ripped today without issue!
