Clarification on flashing LG WP50NB40 (Slim)
Paladinz
Post by Paladinz »
I have just had to purchase an external drive for my new PC and got a LG WP50NB40. When I checked the SDFtool Flasher guide it says
UPDATE - 21/12/2021:
The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START
My drive info shows
Current profile: DVD-ROM
Product: BD-RE WP50NB40
Revision: 1.03
Serial number: SIK02N1VA5340
Firmware date: 2121-07-08 16:09
Do I still need to crossflash and do those instructions apply to slim drives?
Re: Clarification on flashing LG WP50NB40 (Slim)
Paladinz wrote:
Fri Aug 25, 2023 5:35 pm
4. Click START
My drive info shows
Revision: 1.03
If you want to rip UHD then yes, you have to crossflash it. Those instructions are only for the BP50NB40 and WP50NB40 drives with SVC NB52. Just look at the sticker underneath the drive.
Paladinz
Post by Paladinz »
MartyMcNuts wrote:
Fri Aug 25, 2023 7:01 pm
Thanks, mine is NB52.
Lance274
Post by Lance274 »
I have a LG WP50NB40 with SVC code N50. What are the steps? Sp far nothing is working.
Thank you
Lance274 wrote:
Fri Oct 13, 2023 11:49 pm
Thank you
Follow the same procedure as previous comments. I recommend using the BU40N 1.00 firmware in the final step.
Lance274
Post by Lance274 »
I followed the steps
Write the wp50nb40 1.03
select recover and select bn40 1.
No mention of encryption
the result
OS device name: I:
Revision: 1.03
Serial number: [redacted]
Firmware date: 2120-05-07 09:29
Highest AACS version: 81
Firmware version: 1.03
This is with a 4k UHD disk in the drive. MakeMKV was closed and reopened before attempting to read
Lance274 wrote:
Sat Oct 14, 2023 4:21 pm
the result
OS device name: I:
Revision: 1.03
You didn't follow the steps....
You have only done the first part. You need to do the recovery process. Once you select your drive and select recovery, in the popup, you must select the WP50 firmware you already flashed, then in the firmware drop down box, select the BU40N 1.00 firmware.
Lance274
Post by Lance274 »
Thank you for helping me,
I just did this:
4. Click START
After the crossflash a popup window:
Command error code 0x82062900
Lance274 wrote:
Sat Oct 14, 2023 10:38 pm
I just did this:
4. Click START
Did the flash work though? Post your MakeMKV drive info again
Lance274
Post by Lance274 »
No information available
Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 SIM03212K2417' at offset '524288'
Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 SIM03212K2417' at offset '1048576'
Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 SIM03212K2417' at offset '32768'
Lance274 wrote:
Sat Oct 14, 2023 11:24 pm
Power issue use both plugs direct into PC no unpowered USB hubs or get a high powered USB hub
Lance274
Post by Lance274 »
The two USB cables are plugged directly into the computer, just in case I removes and reinserted all the cables.
I redid the flash as above, MakeMKV status:
OS device name: I:
Product: BD-RE BU40N
Revision: 1.00
Serial number: SIM03212K2417
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
Then I inserted a new John Wick UHD disk then
The Info block:
Error:
Lance274 wrote:
Sun Oct 15, 2023 1:31 am
OS device name: I:
Revision: 1.00
The Info block:
Error:
then your computer does not put out enough power simple as that get a high powered usb hub
if its a desktop plug it into the back
Lance274
Post by Lance274 »
I ordered a powered USB Hub, when it arrives I'll try again.
Lance274
Post by Lance274 »
I purchased Rosonway powered USB hub and powered up, connected everything:
Still no joy.
MakeMKV v1.17.5 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 SIM03212K2417' at offset '33363853312'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 SIM03212K2417' at offset '33363916800'
udf: node fe/efe failed!
