Looking for a new Blu Ray drive - Any suggestions?
nikkit17
Post by nikkit17 »
Hi all,
I’m currently looking for a new external Blu-Ray drive so that I can rip my Blu-Rays. It doesn’t have to be a UHD one as o don’t own any of those.
My current drive which is: BD-RW BDR-XD05
Full info:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Firmware date: 2017-06-22
Highest AACS version: 76
status: Enabled
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Unfortunately it doesn’t seem to work anymore :(
Is it just too old? Is it fixable?
If anyone has any suggestions for any fixes that would be great but if not I’m looking for some suggestions for some a drive that does work.
Thanks :D
Re: Looking for a new Blu Ray drive - Any suggestions?
If you want to see if you can save it clean the laser
With a lint free damp microfiber cloth and dry with another
massmodz
Post by massmodz »
Not sure if you are able to repair what you already have, but if not then I would suggest the Pioneer XS07UHD external - Look for Manufacture date of January 2022, anything after that and it's a toss up unless you ask the seller to check the firmware. The reason I suggest that one is because it's built like a tank and the quality is unmatched, you really get what you pay for with that drive. Best bet, ask around on ebay or Amazon and find someone that has old stock... It will save you $$$ vs buying from a seller here for $100 more than it's worth. Or if you prefer internal and you wanna save money look for an ASUS BW-16D1HT and downgrade the firmware.
i suggest a pioneer but defiantly not an asus as its the same junk as a WH14NS40 for almost 2 times the price get the WH14NS40 if your on a Budget.
