Turning Red 4K UHD: read errors
Re: Turning Red 4K UHD: read errors
Your best chances are: Pioneer drives including an "U", LG BU40N - or if you have a 5,25" drive- flash it to WH16NS60 1.03 MK. If still no success- return the discs-
mike12086
Post by mike12086 »
I have two of the WH16NS40 flashed to 1.05. Have worked great so far with every other UHD. Running MKV 1.17.1. If anyone has had success what was their secret and setup?
mike12086 wrote: Mon Aug 08, 2022 11:32 am I have two of the WH16NS40 flashed to 1.05. Have worked great so far with every other UHD. Running MKV 1.17.1. If anyone has had success what was their secret and setup?
Flash them to WH16NS60 1.03 MK. Then try again. See also what themanofsteele reported with his problematic Harry Potter disc.
mike12086
Post by mike12086 »
Coopervid wrote: Tue Aug 09, 2022 9:27 am
Just did it with one of my drives and get similar behavior with I believe some of the same and some different errors. I guess this disc will just go on the back burner and if I ever get another drive of a different make maybe I will try again.
Errors I received:
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00147.m2ts' at offset '224888832'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom2' at offset '224888832'
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00147.m2ts' at offset '224888832'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom2' at offset '224888832'
I don't want to get into the argument of a bad disk since it seems like lots of people had that problem. What I am more interested in is if anyone has ripped it and what their setup was (drive model and firmware).
Return the disc. But sometimes there is a whole batch of bad pressed discs. Then keep returning.
lfoust
Post by lfoust »
I was able to rip my copy from the Disney Movie Club and here is how it laid out: https://thediscdb.com/movie/turning-red ... edition-4k
ThisGuy
Post by ThisGuy »
This inidicates you ripped 801 mpls, which is French
MKVHead21
Post by MKVHead21 »
I'm also having problems ripping this particular disk. I cant get past 580 or so MB. Using LG M Disc Blu-ray Drive - WH16NS60. Brand new disc. Did wipe it down on attempt 2 with a microfiber cloth, still won't rip it.
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00119.m2ts' at offset '257538048'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '257538048'
Failed to save title 2 to file G:/Video/Turning Red/Turning Red_t02.mkv
chrominance
Post by chrominance »
Purchased the Ultimate Collector's Edition with three discs today in Canada, and I also have issues with ripping the 4K disc. Made a few different attempts to rip 00800.mpls and 00801.mpls (as far as I can tell the tracks are identical but they did show slightly different segment maps), and got logs indicating different read offsets for the errors. Looks like the same segment is faulty in every case but it's a different segment than the others reported so far. This is on an unmodified Pioneer BDR-212UHBK from November 2022 (just before the firmware changes, and has ripped every other 4K disc I've thrown at it with no issues). On the attempts where I switched to saving to drive J, that was me trying a tip from further upthread about saving to a flash drive to try and slow down the optical drive, but I think even on USB2 the flash drive write rate is higher than the optical drive can read out so it didn't make a difference.
Saving 2 titles into directory R:/video/movies/uhd/Turning Red (2022)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '467005440'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '467005440'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '468516864'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '468910080'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '469303296'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '469303296'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '469628928'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '469628928'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '477954048'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '477954048'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '478347264'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '478347264'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '478740480'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '478740480'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '479459328'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '479459328'
Failed to save title 0 to file R:/video/movies/uhd/Turning Red (2022)/Turning Red_t00.mkv
Encountered 83 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
1 titles saved, 1 failed
Saving 1 titles into directory J:/Video/Turning Red
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00095.m2ts' at offset '483981312'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '483981312'
Failed to save title 0 to file J:/Video/Turning Red/Turning Red_t00.mkv
Encountered 33 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Failed to save title 2 to file J:/Video/Turning Red/Turning Red_t02.mkv
Encountered 31 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Happy to provide whatever additional logging I can if it might help diagnose/resolve the issue, though I'm guessing since there's been no updates in a year that it could potentially be a lost cause. In the meantime I'm falling back to the Blu-Ray disc, a shame but not the end of the world.
EDIT (Sept. 22 2023): Got in a new LG BP60NB10 and decided to throw this disc at it, and no dice with this one either. This one can't even open the disc's track listing without running into issues, and attempting to rip either of the main features throws similar L-EC UNCORRECTABLE ERRORs in different m2ts files (00040 and 00119 this time).
I also finally got around to watching the 4K in a PS5, and the disc at least plays properly. So I guess it's just a ripping issue. (I've read the commentary about MakeMKV's bit-perfect rips versus players prioritizing potentially glitchy playback over strict error handling, so this isn't intended to be a complaint about MakeMKV.)
Mistress Elemental
Post by Mistress Elemental »
I know this a somewhat old topic, but I was having the exact same issues with different discs with my new drive. (First time trying to rip UHD discs) Normal Blu-Rays had no issues, but UHD, every time it gets to around 20%, same issue. Tested the discs in a stand alone player and had no problems there. I suspected that the drive was reading it too fast and causing issues because once the errors started, I would hear strange issues from the drive, like drive gears were slipping.
I looked into controlling the read speed and there is a way via the registry (for a windows system), but before I could do that, I tried changing the buffer size to 64mb. Was not sure if that would do anything, but once I did that, I was able to copy them. (At least so far, so good) It does take longer to rip the disks, but at least its working. Just thought I would pass this along to anyone else having this issue. I just need to remember to set it back to Auto when I do a blu-ray disc. Using a separate drive for those that can't read UHD to save wear and tear on the UHD drive. If anything changes or I have the issues again, I will update this post, but so far it's been working.
In general, it sounds like your issue is the drive is trying to read faster than it has power to go. Decreasing the buffer causes it to go slower, and it stays within the available power. But that's just by the information you've portioned out to us; not knowing what drive or how it is powered throws a lot of unknown at us.
Mistress Elemental
So I am having the same issue was reported here with two different copies. The first had micro scratches on it, so I assumed it was defective, so I ordered a replacement, got that one, only to have the very same issue, with a very small scratch in nearly the same place. When I have had this problem with other discs, what I did to resolve it is to "Backup" the disc up first without decrypting, then rip from the backup. Clearly that takes a much longer time, but it usually allows me to get past the problem. In this case, it did not work.
I am seeing the same complaints in other forums that is has to do with how Disney is stacking the discs. Stacking on top of each other like they do, causes the scratches which is ridiculous. You would think they would realize this and change how they store the disks. Why are they trying to change something that has worked great for years! I tried running the disk through one of those repair kits, and that did not help either. I am not willing to use the extreme repair method where it literally scrapes off a layer of the plastic to remove the scratches. I would only try that on something I cannot return or exchange as a list ditched attempt.
kevinr
Post by kevinr »
Thank you all for the information posted here. I also was having trouble ripping my UHD 4k disc of Turning Red. I purchased a second copy - the Best Buy Steelbook, in which the disc is stored on a separate spindle, and that one ripped without any issue at all. Seems logical that the micro-scratches on the disc of the standard version (stacked on top of another disc) are causing the ripping issues here.
