Brokenwood Mysteries Series 8
wrldtvlr
Post by wrldtvlr » Thu Aug 10, 2023 3:20 pm
Three disc set, purchased new, no obvious scratches, the first disc rips fine. Second and third have errors. This is the log file from the third disc:
Debug log started at Thu Aug 10 15:14:50 2023 , written by MakeMKV v1.17.4 win(x64-release)
001005:0000 MakeMKV v1.17.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\xxxx/MakeMKV_log.txt
DEBUG: Code 3 at w.G,[.W,J~s[OWwzq<.Q$D1P:29395310
SDF  v098: HL-DT-ST_BD-RE__WH14NS40_1.03_211403261105_K9GEBIG1935
001011:0000 Using LibreDrive mode (v06.3 id=BF04C03F631B)
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
001003:0020 DEBUG: Code 100864256 at Hu0Y6$"G%/26#v|y:121271617
001003:0020 DEBUG: Code 100864256 at spDZ-<~\bXU:/9Ia:213130559
001003:0020 DEBUG: Code 100864256 at XLZy#@p!6m/^{4B`f):121263429
001003:0020 DEBUG: Code 100864256 at XLZy#@p!6m/^{4B`f):121262302
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH14NS40 1.03 K9GEBIG1935' at offset '4153700352'
001003:0020 DEBUG: Code 1 at wYmF2[jips>oCVZP[gZt=WQ:29395586
001003:0020 DEBUG: Code 2028174 at wYmF2[jips>oCVZP[gZt=WQ:213131939
001003:0020 DEBUG: Code 168 at ]aY)Q^BzE6fa_4c`_T".:213133250
001003:0020 DEBUG: Code 16777216 at ]aY)Q^BzE6fa_4c`_T".:121265062
001003:0020 DEBUG: Code 0 at ]aY)Q^BzE6fa_4c`_T".:29394689
001003:0020 DEBUG: Code 1 at wYmF2[jips>oCVZP[gZt=WQ:121263636
001003:0020 DEBUG: Code 0 at U!`"&>w0bVN2/.:29397104
003038:0000 Cells 9-9 were removed from title end
003028:0000 Title #1 was added (8 cell(s), 1:37:33)
001003:0020 DEBUG: Code 2028304 at 50U$77%wM?@GV?:29396184
001003:0020 DEBUG: Code 2028305 at 50U$77%wM?@GV?:213132721
001003:0020 DEBUG: Code 0 at k6Od%gub)Gg3(9hVG):121273641
001003:0020 DEBUG: Code 0 at k6Od%gub)Gg3(9hVG):121274699
003015:0000 Title #2 (1:35:15) was skipped due to navigation error
Title skip vts=1 pgcn=2
003038:0000 Cells 17-17 were removed from title end
003015:0000 Title #3 (3:12:53) was skipped due to navigation error
Title skip vts=1 pgcn=3
003038:0000 Cells 2-2 were removed from title end
003028:0000 Title #5 was added (1 cell(s), 0:02:56)
Application exited at Thu Aug 10 15:17:18 2023
Re: Brokenwood Mysteries Series 8
Post by dcoke22 » Thu Aug 17, 2023 5:05 pm
That error indicates the optical drive was unable to correctly read the disc in that spot. The usual advice is to gently clean the disc and try again.
If you're experiencing rip errors, please read here first!
wrldtvlr
Post by wrldtvlr » Wed Aug 23, 2023 12:19 am
The good news is that the disc reads fine in my internal DVD drive. I had previously been using an external BluRay drive but added an internal drive this afternoon.
