Pioneer BDR-XD08B
ThatOneGuyOverThere
Pioneer BDR-XD08B
Post by ThatOneGuyOverThere » Tue Aug 22, 2023 11:17 pm
Hello I'm new and have purchased this pioneer drive. I have mkv downloaded and was wondering if someone could point me in the right direction on how to get the drive ready to rip 4k blu rays.
I'm a bit clueless with this. Seems like it reads blu rays right away but 4k it says no disc. Any help is appreciated, thanks!
Re: Pioneer BDR-XD08B
Post by Woodstock » Wed Aug 23, 2023 12:17 am
What does MakeMKV say about the drive? A number of Pioneer drives manufactured after December 2022 are currently stalled as far as 4K support is concerned.
Post by MartyMcNuts » Wed Aug 23, 2023 12:25 am
Also, that model is not a UHD drive so cannot rip UHD without being cross-flashed.
ThatOneGuyOverThere
Post by ThatOneGuyOverThere » Wed Aug 23, 2023 11:11 pm
So the one I got from amazon was manufactured in November 2022.
Can this be cross flashed or whatever? Or did I waste my money?
Is there a drive that will just work out of the box for ripping my 4k discs?
Post by MartyMcNuts » Thu Aug 24, 2023 1:15 am
Can't say until you show us your MakeMKV info or at least tell us the firmware date.
ThatOneGuyOverThere
Post by ThatOneGuyOverThere » Fri Aug 25, 2023 10:49 pm
It says it's revision 1.01
It's firmware date is 2022-10-11
It says firmware is original unpatched.
ThatOneGuyOverThere
Post by ThatOneGuyOverThere » Sun Aug 27, 2023 8:20 pm
Was this the info you needed in my last post?
Post by Coopervid » Sun Aug 27, 2023 10:58 pm
It should work. You were to supposed to run Makemkv and copy&paste what is shown on the right side of the screen. So we know. But just try an UHD. It should work.
Post by MartyMcNuts » Sun Aug 27, 2023 11:46 pm
It would need to be cross-flashed to the UHD model to be able to rip UHD discs.
ThatOneGuyOverThere
Post by ThatOneGuyOverThere » Sat Sep 02, 2023 6:31 pm
Ok so how do I crossflash the drive? Is there a program I need or something?
Post by Coopervid » Sun Sep 03, 2023 9:17 pm
Check PM
G-doggy
Post by G-doggy » Fri Nov 17, 2023 4:37 pm
Hello, I have the exact same model and also would like to know how to crossflash. Or whatever else to get it to read uhd.
Post by Coopervid » Sat Nov 18, 2023 11:07 am
Check PM
Psycomo
Post by Psycomo » Sun Aug 11, 2024 12:34 pm
I also have this drive. How do I crossflash?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.01
Serial number: [redacted]
Firmware date: 2022-10-11
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.01
Post by Coopervid » Sun Aug 11, 2024 6:43 pm
OS device name: E:
Revision: 1.01
Read your PM.
