LG WH14NS40 sdf tool throwing error while flashing
darkKaplah
Post by darkKaplah »
So long time makeMKV user and I paid for a key (hey you guys make awesome software!). Just noticed my drive is a LG WH14NS40 and it shows libre support. So I tried to flash the software for my model. I'm getting the following error that's attached in the screenshot. It doesn't matter if I have the "enc" checked or unchecked, or if I run as administrator.
This machine is a windows 11 box.
Love to know what the issue is. The drive still works so this isn't a hair on fire scenario. I do get the occasional UHD so I'd love to be able to rip those, but again not dire.
(Edit) Aparently the attachment didn't go through. Here's a link to the photo:
https://photos.app.goo.gl/tJ5doduLWirer5ot5
Re: LG WH14NS40 sdf tool throwing error while flashing
darkKaplah wrote: Tue Aug 22, 2023 1:22 am So long time makeMKV user and I paid for a key (hey you guys make awesome software!). Just noticed my drive is a LG WH14NS40 and it shows libre support. So I tried to flash the software for my model. I'm getting the following error that's attached in the screenshot. It doesn't matter if I have the "enc" checked or unchecked, or if I run as administrator.
There is no image attached. Try uploading the image somewhere and providing a link or tell us the error. Also, show us your MakeMKV info (right hand pane). Hopefully we can help you out...
Your drive has v1.05 which is an encrypted firmware. Therefore you cannot directly flash to WH14NS40 1.02 firmware. You should flash to WH16NS60 1.02-MK firmware first, then you can flash to the other firmware if you want, although I suggest you flash to WH16NS60 1.02-MK and leave it as that is the recommended firmware and works well with MakeMKV.
I also suggest using the latest version of SDFtool Flasher (v1.3.5 I think?).
darkKaplah
That was the solution! Thank you sir. I've updated my drive to the WH16 as you suggested and I'm showing libre enabled. Now to screw around with this a little.
I'll need to do the same to my other drive in my truenas/arm box. Worse case scenario I'll need to just swap drives, but is there a linux flasher for the firmware?
darkKaplah wrote: Tue Aug 22, 2023 4:09 pm That was the solution! Thank you sir. I've updated my drive to the WH16 as you suggested and I'm showing libre enabled. Now to screw around with this a little.
No but you can use the command line.
Firesaif
Post by Firesaif »
I tried doing this today and I got a error message with both versions Image
Need help please :(
Screenshot 2024-12-20 111317.jpg (10.28 KiB) Viewed 5661 times
Firesaif wrote: Fri Dec 20, 2024 4:19 pm I tried doing this today and I got a error message with both versions Image
Need help please :(
More info required....
What drive? What firmware is on the drive? What firmware are you trying to flash? Provide the drive/libredrive info from MakeMKV.
